Hi
OK so I went ahead and made two spacer feet that simply slide over the factory molded front feet and lock in place. The feet lift the scope a few millimeters to increase the space for exhaust cooling air to escape. The only exit for cooling air is a grill in the base of the enclosure.
As always, I try and make my mods look like they are factory made. The new feet are close to the factory colour so it is not obvious the feet are fitted. No screws, no holes, no modifications to the enclosure and all completely reversible.
I included a shallow relief for gluing on a piece of rubber roofing material. The rubber will provide some extra grip and reduce noise transmission by at least a few femtodecibles.
Just in case someone wants to do the same mod, I have also attached the 3D file of the design. I printed with PETG.
On a scale from brilliant to useless, this mod definitely leans to the useless side, but I got to design and make something.
