Author Topic: LCD BACK SILVER STICKER  (Read 1209 times)
Offline samsonTopic starter
« on: January 27, 2023, 12:02:47 am »
Hi, could any one tell were I can buy the silver backing that there is on all LCD meters watches ect. What is it called?
I have a fluke Multimeter and the lcd is find but the silver backing that is on the back of the lcd has faded.
any help would be appreciated.
Offline Swainster
  • Country: sg
Re: LCD BACK SILVER STICKER
« Reply #1 on: January 27, 2023, 06:33:24 am »
I would have thought that the reflective layer is built into the rear polarizer, so maybe search for 'LCD reflective polarizer'?
Offline shakalnokturn
« Reply #3 on: January 28, 2023, 11:17:36 pm »
Any links for a semi-transparent version, usefull if you want to add backlighting to a LCD that wasn't backlit from scratch?
Offline Gyro
« Reply #4 on: January 29, 2023, 09:55:20 am »
Irrc, the magic word used to be 'transflective'. I don't know if it still is.
Best Regards, Chris
The following users thanked this post: shakalnokturn
« Reply #5 on: January 29, 2023, 09:57:49 am »
Thank you for the reply. This one goes on the front of the LCD. I need the silver one that goes on the back . It is not see thru and it's got a self adhesive and very thin
« Reply #6 on: February 02, 2023, 11:10:07 am »
Any help please as I am a lost were to buy this silver backing tape.
Offline eswan
« Reply #7 on: February 02, 2023, 03:28:16 pm »
I've used 'Aluminum Foil Tape' in the past with good results. Managed to find it in 8 inch widths. Used in sealing HVAC ducts.
Offline Gyro
« Reply #8 on: February 02, 2023, 07:43:57 pm »
Silver reflective Polyester / Mylar tape seems quite common on ebay.
P.S. I don't know whether the adhesive would be sufficient to give the desirable matt finish.
« Last Edit: February 02, 2023, 07:58:44 pm by Gyro »
Best Regards, Chris
Online jpanhalt
« Reply #9 on: February 02, 2023, 08:11:26 pm »
You seem desperate and none of the suggestions seem to have helped.  Have you considered checking out "window tinting + silver". Lots of hits, some call it security tinting.  Even Amazzon sells it: https://www.amazon.com/s?k=silver+window+film&gclid=EAIaIQobChMI7_bSvNH3_AIV3DizAB1h1A3cEAAYAyAAEgLj6vD_BwE&hvadid=174266262177&hvdev=c&hvlocphy=9015589&hvnetw=g&hvqmt=e&hvrand=2855478611731995545&hvtargid=kwd-253406574&hydadcr=8434_9618941&tag=googhydr-20&ref=pd_sl_82oexfuudb_e
As a last resort, mirrors are silvered (front or back surface) with Tollens reagent.  It's ancient technology and works well.  The only expensive reagent you need is silver nitrate.  Scan down to "in silver mirroring:" https://en.wikipedia.org/wiki/Tollens%27_reagent
