Thanks.
Watched the 34970A slowly die and set it aside until I could afford a replacement.
As I recall, factory wanted $850 for replacement and a tech rental shop was offering $750 w/ 34902A earlier this year.
Somehow the other day ended up here.
Battery voltage read 0.15V.
Under $10 for new battery from Mouser.
Un-soldering w/Pace station.
Tip touched round hole next to pin and spark blew all the solder out around terminal.
Ohmmeter readings show that that hole is connected to the terminal?
![Huh? ???](https://www.eevblog.com/forum/Smileys/default/huh.gif)
Like the + terminal is connected to its close hole.
Judiciously replaced the battery and back in operation.
