Author Topic: Agilent 34405A USB connection  (Read 3348 times)
Offline TonPTopic starter
« on: September 04, 2015, 05:55:27 pm »
Try to do a Firmware update or connect a Agilent 34405A to Benchvue but without succes.
After trying 4 different computers ("try an older model pc, adviced on the Keysight forum")
Did I need a Windows XP machine? Somebody solve this problem allready?
Offline babysitter
  • pushing silicon at work
Re: Agilent 34405A USB connection
« Reply #1 on: September 04, 2015, 07:33:08 pm »
Hi Ton,
have one at work, this device is a PITA. Unreliable USB for several years, crashing during a recommended update, a failure got USB cable getting hotter than reasonably possible(USB limit 5W, right?), 4th device exchange in  IDK, 5 years?
Throw it as far as you can. Sell it, get something nice.
I'm not a feature, I'm a bug! ARC DG3HDA
Offline HighVoltage
« Reply #2 on: September 07, 2015, 07:23:44 pm »
The Agilent 34405A is NOT an Agilent development.
I also had one before and did not like it at all and got rid of it.
Online Thomas
  • Country: no
« Reply #3 on: September 08, 2015, 07:14:27 pm »
I've had issues with mine too, unreliable USB.
But after the latest firmware, it seems to be cured. The update took a few tries before it went without an error message.
The first update (years ago) messed up the serial number, but I don't care ::)
So my tip would be to keep trying to update the firmware. I had the Keysight IO Libraries Suite installed when I did this, not sure if that matters.
I tried several times before it suddenly worked, for no apparent reason.
« Reply #4 on: September 22, 2015, 05:40:28 pm »
I fix the problem. Luckely i dont trow al my old XP machines away.   :-//
Dont ask me how I did it. I dont know but it works fine now. Also with Benchview, no problems at all. :-+
Offline KrzysiekG
« Reply #5 on: December 30, 2015, 10:42:40 pm »
Do you encounter a problem during upgrade your multimeter like this:
http://www.keysight.com/owc_discussions/thread.jspa?messageID=117849
I asked Agilent but they were unable to explained me why my multimeter won't start upgrading...
