I have seen a video on YouTube where there is conclusion that the 2 analog waveforms are not in sync with the digital logic channels when doing measurements.
Yes, I saw that some time ago. That was the hilarious conclusion. Had me laughing hard for a long time.
This seems weird, as isn't that the whole purpose of an MSO. Was this an initial bug and has it been solved in the Rigol DS1102D?
This was never 'solved', or 'fixed', because there was nothing wrong with the Rigol. What it showed was exactly correct. It was just another of
many situations where an inexperienced operator
couldn't understand what he was seeing, and thus concluded the Rigol LA must be broken.
Unfortunately, that happened a lot.
His 'solution' was brilliant though: dump the untrustworthy Rigol. And switch to a different device, that had
no way for you to see the confusing analog signals, along with the digital. That 'fixed' it, good and proper.
Please provide feedback if it has been improved in the new firmware?
Nope. As I said. Never fixed, because it was never broken.
The PC Logic analyzers only provide digital channels, so they don't combine analog waveforms at all, so the MSO should do the job properly, as it is only way to combine analog and digital, and have them synced.
Yes, that's correct. But when you crank the timebase up to max, and are looking at signals in the nanosecond time-frame, you have to remember to consider the speed of light (or more accurately, signal propagation in the cables at ~0.95c). And pay some attention to the lengths of the cables you are using. I didn't go back and replay it, but as I recall, he was seeing unexplained shifts around 4-8 ns? Then ask yourself how long it takes for a wave to travel through a foot of cable. Lastly, look at the probes & cables he was using.
You also need to know exactly where each signal is being 'acquired'. And it may not be where you first imagined.
Otherwise, you wind up asking yourself how a scope could be showing you the arrival of a signal, several nanoseconds
before it was generated!
It's incredible! It's amazing!
(It's impossible.) Now if I were seeing that, I might conclude I didn't understand it (at first). But not that the equipment was defective.
[And just to be clear, with the exception of a few erroneous conclusions, I thought Rich did a nice, careful, and well-described review of many capabilities that no one else ever bothered to do. They just wrote it off as non-functional, and moved on. Rich took the time to set up a test circuit, and walk through the whole process. Which was educational. He also has some informative criticisms, and suggestions for improvement, which I mostly agreed with.]
