The board in question is a 16717A, and I have five more of them in varying states of (dis)repair.
That said, here's the results:
Test results from x modtests. Mod D is the device under test.
Mod D: TEST passed # "vramDataTest" (2, 0, 1)
Mod D: TEST passed # "vramAddrTest" (2, 0, 1)
Mod D: TEST passed # "vramCellTest" (2, 0, 1)
Mod D: TEST passed # "vramUnloadTest" (2, 0, 1)
Mod D: TEST passed # "chipRegTest" (2, 0, 1)
Mod D: TEST passed # "bpClkTest" (2, 0, 1)
Mod D: TEST FAILED # "cmpTest" (2, 2, -1)
Mod D: TEST passed # "icrTest" (2, 0, 1)
Mod D: TEST passed # "flagTest" (2, 0, 1)
Mod D: TEST passed # "armTest" (2, 0, 1)
Mod D: TEST passed # "vramSerDataTest" (2, 0, 1)
Mod D: TEST passed # "vramSerCellTest" (2, 0, 1)
Mod D: TEST passed # "clksTest" (2, 0, 1)
Mod D: TEST passed # "calTest" (2, 0, 1)
Mod D: TEST passed # "zoomDataTest" (2, 0, 1)
Mod D: TEST passed # "zoomMasterTest" (2, 0, 1)
Mod D: TEST passed # "fisoRedundancyTest" (2, 0, 1)
Mod D: TEST passed # "zoomAcqTest" (2, 0, 1)
Mod D: TEST FAILED # "zoomChipSelTest" (2, 2, -1)
Results from tests using x cmpTest and x zoomChipSelTest with debugLevel set to 9 and resultLevel set to 9. There are 4 successive tests shown below.
Check POD1 Thresholds:
Slot D, Chip 9: B BBBBBBBB BBBBBBBB B BBBBBBBB BBBBBBBB Cal Clk No Act.
Slot D, Chip 8: B BBBBBBBB BBBBBBBB B BBBBBBBB BBBBBBBB Cal Clk No Act.
Slot D, Chip 9: B B..BBBBB BBBBBBBB . ........ ........ Cal Clk Levels
Slot D, Chip 8: B B....B.. .BBBBBBB B B...BBB. .BBBBBBB Cal Clk Levels
Slot D, Chip 9: B BBBBBBBB BBBBBBBB . ........ ........ Cal Clk Activity
Slot D, Chip 8: B BBBBBBBB BBBBBBBB B BBBBBBBB BBBBBBBB Cal Clk Activity
Check POD2 Thresholds:
Slot D, Chip 9: B ........ BBBBBBBB B BBBBB.BB ........ Cal Clk Levels
Slot D, Chip 8: B BBBBBBBB B....BBB B BBBBBBBB B.....B. Cal Clk Levels
Slot D, Chip 9: . ........ ........ B BBBBBBBB BBBBBBBB Cal Clk Activity
Check POD3 Thresholds:
Slot D, Chip 9: . ........ ........ . ........ .B.B.... Cal Clk Levels
Slot D, Chip 8: . BBB..... ........ B B..BBBBB BBBBBBBB Cal Clk Levels
Slot D, Chip 9: B BBBBBBBB BBBBBBBB B BBBBBBBB BBBBBBBB Cal Clk Activity
Slot D, Chip 8: B BBBBBBBB BBBBBBBB . ........ ........ Cal Clk Activity
Check POD4 Thresholds:
Slot D, Chip 9: . .BB..... ........ . .B...... ........ Cal Clk Levels
Slot D, Chip 8: . ........ .BBB.... B BBBBBBBB B...BBBB Cal Clk Levels
Slot D, Chip 8: . ........ ........ B BBBBBBBB BBBBBBBB Cal Clk Activity
> Slot D: Comparator Test Failed!
Slot D, Chip 9: . ........ ........ B BBBBBBBB BBBBBBBB Cal Clk Levels
Slot D, Chip 9: . BBBBB.BB B....... B B...BBB. BBBBBBBB Cal Clk Levels
Slot D, Chip 8: . BBBB.B.B ........ . BBBB...B ........ Cal Clk Levels
Slot D, Chip 9: B BBBBBBBB B....BBB B BBBBBBBB B....BBB Cal Clk Levels
Slot D, Chip 8: . BBBBBBBB ........ B ....B.B. BBBBBBBB Cal Clk Levels
Slot D, Chip 9: . BBBBB..B ........ . BBBB.... ........ Cal Clk Levels
Slot D, Chip 8: B BBBBBBBB B....BBB . ........ .BBBB... Cal Clk Levels
Slot D, Chip 9: . .BB..... ........ B B.BBBBBB BBBBBBBB Cal Clk Levels
Slot D, Chip 8: B ........ .BBBBBB. . .....B.. .BBBBBBB Cal Clk Levels
Slot D, Chip 9: . ........ .BBBB... B BBBBBBBB B....BBB Cal Clk Levels
Slot D, Chip 8: B BBBBBBBB B...BBBB B BBBBBBBB B...BBBB Cal Clk Levels
Slot D, Chip 9: . BBBBB..B ........ . BBB..... ........ Cal Clk Levels
Slot D, Chip 8: . ........ .BBBB... B BBBBBBBB B....BBB Cal Clk Levels
Slot D, Chip 9: B ........ .BBBB... . ........ .BBBB... Cal Clk Levels
Slot D, Chip 8: . .B...... ........ B BBBBBBBB BBBBBBBB Cal Clk Levels
Slot D, Chip 9: . BBBBBBBB .....B.B . ........ BBBBBBB. Cal Clk Levels
Slot D, Chip 8: . .BB..... ........ . .B...... ........ Cal Clk Levels
Slot D, Chip 9: B B...BBBB BBBBBBBB B B..BBBBB BBBBBBBB Cal Clk Levels
Slot D, Chip 8: B BBBBBBBB B...BBBB . ........ .BBB.... Cal Clk Levels
Slot D, Chip 9: . BBBBBBBB B....BBB B BBBBBBBB B....B.B Cal Clk Levels
Slot D, Chip 8: . BBBBBBBB B....... B B...BBB. .BBBBBBB Cal Clk Levels
After running this test, I did another 'x modtests' -- and the "vramSerDataTest" failed for the first time since plugging in the module, which makes me concerned that any corrosion internal to the board is getting worse. I subsequently stopped the test sequence and then re-ran the vramSerDataTest another 100 times -- it passed 100 out of 100, so maybe it's a fluke.
Next is the results of two runs of x zoomChipSelTest with debugLevel set to 9 and resultLevel set to 9.
Slot D: Filling FISOs for Pods #1 with zeroes...
Slot D: Checking FISO #4...
Slot D: Checking FISO #3...
Slot D: Checking FISO #2...
Actual = 0xffff, Expected = 0xadff
Slot D: FISO #2 failed.
Slot D: Checking FISO #1...
Actual = 0xffff, Expected = 0xad5a
Slot D: FISO #1 failed.
Slot D: Checking FISO #0...
Slot D: FISO #0 failed.
Slot D: Filling FISOs for Pods #2 with zeroes...
Actual = 0xffff, Expected = 0xdaff
Actual = 0xffff, Expected = 0x5aad
Slot D: Filling FISOs for Pods #3 with zeroes...
Slot D: FISO #4 failed.
Slot D: FISO #3 failed.
Actual = 0xffff, Expected = 0xffad
Slot D: Filling FISOs for Pods #4 with zeroes...
Actual = 0x888, Expected = 0xadda
Actual = 0x808, Expected = 0xad5a
Actual = 0x8808, Expected = 0xff5a
Actual = 0x808, Expected = 0xffff
> Slot D: Zoom Acquisition Chip Select Test Failed!
Actual = 0x888, Expected = 0xffff
Actual = 0x8808, Expected = 0xdaff
Actual = 0x808, Expected = 0x5aad
Actual = 0xffff, Expected = 0xadda
Actual = 0xffff, Expected = 0xff5a
