Author Topic: Agilent 1156A Teardown  (Read 6906 times)
Offline Gandalf_SrTopic starter
« on: February 06, 2016, 05:30:40 pm »
I recently bought an Agilent MSO7104B and took a chance on buying a probe on eBay that ended up being a dud - it was stuck on 25 volts indicated output and the business end got warm.  I have this idea to build some 1GHz probes of my own and, initially I may reuse parts of the dud 1156A but I'll post that separately.
I contacted Keysight to ask about a repair but they quoted me $1,569 which is crazy considering that the recommended replacement, an N2795A 1 GHz active probe lists at $1,050
So I decided to do a teardown.  First the bit that plugs into the Autoprobe interface on the scope...
If at first you don't succeed, get a bigger hammer
Re: Agilent 1156A Teardown
« Reply #1 on: February 06, 2016, 05:33:01 pm »
I removed the plastic bayonet locking device and then took the BNC assembly out of the housing.
« Reply #2 on: February 06, 2016, 05:34:58 pm »
Next we unplug the PCB and look at the reverse side of it
« Reply #3 on: February 06, 2016, 05:36:38 pm »
Another view of the PCB top side and the housing it fits into.  That spring-pin assembly comes out if you push the pins in and then carefully lift the inside edge
« Reply #4 on: February 06, 2016, 05:38:14 pm »
Then I looked inside the business end using a microscope (it's small) - here I think we get an idea of why it doesn't work.
« Reply #5 on: February 06, 2016, 05:39:34 pm »
The business end electronics fit inside a small brass shell shown in these pictures..
Offline _Wim_
« Reply #6 on: February 07, 2016, 06:51:24 am »
Nice pictures! Very interesting...
Offline TiN
  • Country: ua
    • xDevs.com
« Reply #7 on: February 07, 2016, 07:07:30 am »
Did you try putting back missing capacitor? It might be OK after all (if gold bond wires are intact).
Online edpalmer42
« Reply #8 on: February 07, 2016, 07:47:26 am »
The two resistors on the end are laser-trimmed.  I can't tell if they're blown or not.  Compare the picture of the tip with the one on this page:  http://willhb.com/2014/07/agilent-active-probe/ .  They don't look that different.
Offline HighVoltage
« Reply #9 on: February 07, 2016, 08:52:08 am »
Very impressive
Is keysight offering parts for this, if you are repairing it yourself?
Offline TheSteve
  • Living the Dream
« Reply #10 on: February 07, 2016, 09:28:18 am »
Indeed, get a capacitor installed.
VE7FM
Offline crispy_tofu
« Reply #11 on: February 07, 2016, 09:49:21 am »
Very cool.  :-+
Offline TinkerFan
« Reply #12 on: February 07, 2016, 09:55:28 am »
Really nice pictures  :-+ :-+
I know Shahriar (TheSignalPath) made a teardown of an InfiniMax III N2802A 25GHz probe  a while ago. There might be some useful information for you in that video and if not, it is still very interesting
http://thesignalpath.com/blogs/2015/09/05/teardown-analysis-of-a-keysight-infinimax-iii-n2802a-25ghz-active-probe/
"A good scientist is a person with original ideas. A good engineer is a person who makes a design that works with as few original ideas as possible. There are no prima donnas in engineering." - Freeman Dyson
Offline HAL-42b
« Reply #13 on: February 07, 2016, 09:57:49 am »
So this one is missing one cap and the other one is missing another one. What's the deal here? Do the caps just fall off or are they not installed at the factory as a part of some sort of trimming process?
« Reply #14 on: February 07, 2016, 01:29:00 pm »
Very impressive
Good question.  I contacted Keysight and got a quote for repair... $1,569 which is more than the $1,059 list price of the N2795A 1GHz active probe that is the 1GHz recommended replacement.  The people I spoke with agreed that it seemed wrong but were unable to persuade anyone to alter the price.
I will try replacing the capacitor - it's worth a try.
Thanks for all the positive remarks about the photos, believe it or not I looked around for my 14 Mpixel Canon but couldn't find it so I took the pictures using my iPhone 6+
Online edpalmer42
« Reply #15 on: February 07, 2016, 02:39:10 pm »
Considering how small they are, maybe just dropping the probe could break off a capacitor.  Something like a conformal coating would help to hold everything on the board.
« Reply #16 on: February 07, 2016, 03:23:24 pm »
Just looked at the head unit under the microscope, there are 2 wire bonds broken at the top side of the bare die package so I'm basically giving up on the repair.  I think I'll try to hook up my new home brew FET probe to the scope end of this lead and take power supplies from it too.
Offline Neganur
« Reply #17 on: February 07, 2016, 03:53:46 pm »
Any chance you could post that last probe shot? I wonder if that could be fixed with the right tools (bonding machine here)
« Last Edit: February 07, 2016, 03:59:36 pm by Neganur »
« Reply #18 on: February 07, 2016, 11:44:38 pm »
Thanks for the offer but I cut the coax cable off already :(
