Vintage Teardown: RFT G-1004.501 (DMM)
Part Nr. 1 - The outsides!
Greetings!
Mayhaps stuff like this is kinda interesting for some folks. Its a simple one but i do like this old stuff and tech
This particular unit was sold on:
25. October 19903 1/2 CountsDC V ranges: 200 mV, 2 V, 20 V, 200 V (0,25% +2) // 1000 V (0,5% + 2)
DC A ranges: 200 mA, 2 mA, 20 mA, 200 mA, 1000 mA (0,5% +2) // 10 A (1% +2)
AC V ranges: same as DC (1% +4 for all ranges)
AC A ranges: same as DC (1,25% + 4 for all ranges)
Ohms: 200, 2k, 20k, 200k, 2000k, 20M (0,5% +3)
Diodetest: 0,1 mA / 0 - 1,999 V (max. out: 3,4 V) + Continuity
Batterylife: >1500 h
This meter seems to be working just fine, except for the black zones within the LCD. So far it seems to be within spec! So nothing to repair i guess
For the first post, i'll show some pictures from the outside, the battery compartment and the schematics. There will be more from the inside later this week.
With the original box, documents in rus + ger language, schematics and a warranty card its quite a good catch!
The display (9mm in heigh) has its problems. But its usable! I could remove the polarization filter
But as some of you know, it wouldn't be usable from that point forward.
The original schematics. In this case the RUS variant. The other one would be in german.
The bottom side with some markings like "RFT veb mikroelektronik >karl marx< erfurt" (RFT = Rundfunk- und Fernmelde-Technik / veb = Volkseigener Betrieb [publicly owned enterprise) and yes, this meter needs 6 batteries! And no, your eyes don't deceive you ... i use miserable Vartas. I had these on hand. I'm sorry! Please put the stones back to the ground where they belong and don't use them as a throwing weapon!
