Apart from a few (unsuccessful?) repair threads, there doesn't seem to be much info on Eevblog about the IFR 3413, IFR 3414 and IFR 3416 sig gens from Aeroflex / IFR.
I've attached the datasheet below.
The aim of this thread is to discuss the good and bad points about these sig gens and how they compare to the competition. I'm a long time user of these sig gens having used many of them at work for about 20 years and I also have a few of them here at home.
At first glance, these sig gens look quite similar to the older Marconi 2023/4/5 analogue sig gens and they share a similar layout. However, the IFR 341x generator is a vector signal generator, and this allows almost any form of modulation to be generated up to about a 50MHz bandwidth using the I and Q inputs of the vector modulator.
The vector modulator(s) used in these sig gens have high performance, and this allows these sig gens to generate digital modulation with very low distortion on an adjacent channel. To maintain the low distortion through the whole signal path to the output, these generators also feature high performance amplifiers in the signal path.
This is great for manufacturers of modern wireless systems, as they can use these sig gens to produce spectrally pure test signals with various forms of digital modulation.
The power consumption is quite high compared to a classic analogue generator such as the Marconi 2024. These generators also run quite hot internally and they produce a fair bit of fan noise when fully warmed up. The amount of fan noise may depend on the version of the hardware. It appears the later models have improved thermal management so they run cooler and quieter and should be more reliable.
The 4GHz IFR 3414 typically consumes 125W when running. Compare this to just 70W for the Marconi 2024 and just 25W for the Marconi 2022. Both these sig gens produce significantly less fan noise than the 341x series.
These IFR 341x sig gens are generally quite expensive on the used market despite their age. This is probably because of the high performance they offer via the vector modulator and there may be regular industry demand for drop in replacements when they fail.
They were designed to be serviced via module swapping and so there isn't much info available for component level servicing. This makes it difficult for companies to get these generators repaired when they fail and this probably maintains demand for working examples.
The close to carrier phase noise is quite high on these sig gens because the vector modulator operates up at UHF and this is downconverted to lower frequencies when applicable. So the phase noise at (say) 14MHz is as high as the phase noise up at UHF. This makes this sig gen a poor choice if you expect low phase noise across the HF bands and into VHF. The phase noise really is quite high on this generator across HF and into VHF.
I can post up some performance plots and add info about reliability and what often fails on these sig gens.
Does anyone here have one of these generators? Has it been reliable and are you pleased with it?
