Author Topic: Advice on Voltage tester and Meter for electronics/industrial electrical, long  (Read 7313 times)
Offline rwgast_lowlevellogicdesinTopic starter
    • LowLevel-LogicDesign
Ok so i've finally got back to work as a union electrician with I.B.E.W (was away for 5 years doing other things), I'm currently at a HUGE 550 megawatt solar plant! I also do lots of hobby electronics projects, I love micro controllers and programming. Recently I have been watching more and more of the EEVBlog and designing some analog stuff. I use a 30 dollar rebadged mastech, it has done the job fine for low voltage. The issue im having with it now that im getting in to analog is its precision is not anywhere near advertised! I have tested it against a 9 dollar wally world hunk of junk using precision resistors and voltage references and the 9 dollar meter is much more accurate... go figure!
So this is basically the dilemma I am having, as far as a voltage tester goes...  I.B.E.W gives you a tool list, these are the tools we are suppose to supply ourselves and if we need anything other than that the contractor must supply it. Well one of the the tools is a voltage tester (wiggens/wiggy style solenoid based tester highly recommended), I use to own an Ideal branded solenoid tester and sold it when I left. It is getting harder and harder to find a solenoid tester these days, you can't just walk in to home depot and buy one. I have searched online and found a few, but there is not a huge selection. When searching amazon for a wiggens voltage tester I actually get a bunch of testers back, with good brand names like Fluke and ExTech. The thing is they are all solid state testers that look like a wiggins style tester with the solenoid. When searching for solenoid voltage tester, this is what I get
http://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Daps&field-keywords=solenoid%20voltage%20tester&sprefix=solenoid+vo%2Caps&rh=i%3Aaps%2Ck%3Asolenoid%20voltage%20tester&sepatfbtf=true&tc=1367698997799
As you can see there are a few solid state Flukes in that search, but mostly mechanical solenoid testers. The problem is Ideal is the only brand I have ever heard of and it is solid state.
So here is the deal... I love electricity. I am deeply in to hobby electronics (hope to one day merge that into my career), I'm a Union sparky and I have a lot of fun at my job. When I buy test equipment I want to buy the best quality stuff I can afford that will last and be suitable for work and home use. Im not sure what I should do in this situation. All the electricians I have ever talked to give a few good reasons for using a solenoid based tester, and Im not sure if there just older guys who are full of it like the people who say Analog sound gear and tubes sound better than digital... I'm sure there reasons for using a solenoid are correct, just not sure if there the whole story.
First off to me the biggest reason for using a solenoid tester is something called phantom voltage. Apparently Some times you can test a receptacle with a solid state tester/digital meter and get a "phantom reading", i.e voltage that isn't really there.  I'm not even sure why this would happen, capacitive coupling from the neutral wire maybe? Apparently a wiggly style meter will not detect a phantom voltage because the solenoid puts an actual load on the circuit so if there is no current there, theres no power to move the solenoid. This argument sounds logical to me and the biggest plus. The second biggest advantage to the solenoid tester ties in to the first, they test voltage by creating a load on the line which means NO BATTERIES, yay! Third thing I have heard and what I believe is mostly likely just a biased myth carried on from the older guys is that a solenoid meter is the most reliable and rugged, apparently a lot of guys will trust a 40 year old wiggy over a solid state tester.
So what should I pick up, I would think a nice solid state fluke is the best option, but if a wiggins style is really better I am a bit stumped on what to buy. Like I said I have never heard of any of the manufactures I saw on amazon besides Ideal, which I have always thought was a bit of a cheap brand trying to steal Klein's clout in the industry. I know Klein also makes meters and testers and they were a top brand on my list until I realized they were rebadged, plus there testers are also solid state!
Now I am also looking for a GOOD meter <= $200! but this is really hard I've been looking at all the big players sites, BK, Agilent, Fluke, Extech etc. I've also been watching Dave's meter reviews and teardowns. separate having a hard time finding what I want, without buying a bench meter, out of my price range. I'm not sure if buying separate pieces of gear to do separate tasks is the way to go, or buying one meter that does it all. I would like a GOOD solid meter to use for electronics, but I would also like it to double for a meter at work when needed. Granted a meter is not on our union tool list, and bringing one to work is "wormy", if we need a meter the contractor needs to supply it! I feel a bit different on this issue, Lets say Im working and need a meter. The contractor will probably supply one but I probably wouldn't bet my life on it. When using a meter at work I could be doing anything from 480v switchgears and 600v panel swaps, to commissioning (testing) solar panels. As far as if I ever needed to bring a meter to work I need something I can put my life on with hi voltages, and two features I would really want is the ability to use an amperage clamp and some type of safety as far as plugging leads in wrong.
As far as needs at home, which is where this meter will spend 98% of its life.. I want good accuracy especially when reading resistors and shunts.  The standard .5% ohm is probably about what I actually need, as long as the meter has the advertised accuracy, all my meters are advertised at .5% and they don't meet that at all, nor will they measure down to .005 ohms for hi side current shunts. As far as voltage accuracy goes It would be nice to get within 10 microvolts accuracy at the 0 to 10v range, but this is not a concrete requirement. The other features i'm looking for is to 50, frequency (my mastech reads 60Hz 90% of the time even with no mains reference I would hope to avoid this) up to 500khz~1Mhz. Diode test that can do LEDs. Capacitance hopefully up to about 400uF. Transistor HFE tests.
I would also like LCR/ESR features but this is where I am running into issues most good hand meters don't have these features only, nor do they have very low/hi capacitance measurements. I have found a ton of multimeters that advertise LCR/ESR but they are all cheapo $50 meters on e-bay and I'm sure they aren't worth a crap.  This is where I am wondering if buying a separate LCR/ESR meter is actually the better decision.  I have seen a few good meters that have LCR/ESR but they are all $700+ or bench top, while a separate ESR meter is much cheaper.
Offline Lightages
  • Canadian po
For what you are doing/want to do, there aren't many choices. There are a couple of multimeters that have a low impedance mode for eliminating phantom voltages but I can't recall which at this point.
For the kind of work you are implying and accuracy you want you can forget <$200.
I would like to suggest a Brymen BM869. It is very well built and has CATIV/1000 volt rating and high accuracy. I have one and I can say that it is a very good buy but over your $200 limit, closer to $290 with shipping. With the kind of energy sources you say you will be working with you need this level of CAT rating. There are Flukes that I would recommend but you are getting up to $400 and way over.
With the energies you will be working with, please consider at least the Brymen BM869 or a higher end Fluke. When it comes to that level of safety $100 more is nothing compared to a lost finger or eyes. Forget transistor testing in a multimeter, they are included as a feature just to sell shitty meters and any meter that has this feature is instantly to be considered junk. No hand held multimeter is going to be accurate to 0.005 ohms.
Perhaps the do it all meter that might be right for you is the Amprobe 37XR-A, around $140. It is not as highly rated for safety as the Brymen BM869 but it it has a few more functions.
Really, you are better off with a good safe meter for electrical work, and a good LCR meter for precision component testing. Sorry, but <$200 is not going to do everything you want. I think with your requirements you are looking at $500+
« Last Edit: May 05, 2013, 03:09:53 am by Lightages »
I have checked in to the bryman bm869, I can't for the life of me find a place that sells it in the US, nor can I figure out if there is a greenlee equivalent.
As far as work goes for right now just a decent tester, will suffice. What Meters would you recommend if I were just looking for those features on the electronics side of things? All the accuracy stuff I listed is mostly for electronics home use, so maybe the better choice would be to get a decent meter with the functions and accuracy I listed above for electronics, and then go out and get a solid CATIV meter with just the basics which I can plug an amp clamp in to?
Offline PedroDaGr8
  • A sociable geek chemist
At work, I have a Fluke 116 (we had to get a multimeter with temp function which could be calibrated, FDA rules even though the stuff I make isn't FDA applicable) this has a Lo-Z function. Which according to the Fluke website:
LoZ function prevents false readings due to ghost voltage
It appears the Fluke 114, 116 and 117 meters have this function. Not sure if that helps or not.
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves, "You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." -George Carlin
Offline retiredcaps
Greenlee DM-860A
http://www.greenlee.com/products/DMM-500K-COUNTS-(DM%2540d860A).html?product_id=19551
Offline IanB
I looked on Amazon and there seem to be several different wiggens style vibrating solenoid voltage testers available with good reviews, including several Ideal branded ones. If electricians like them and recommend them, just get one.
As far as multimeters go, I think there are two kinds.
On the one hand there are industrial meters, very rugged and with strong safety features. You can take these to the job site and use and abuse them with confidence. With these meters you are going to pay for the input protection and durability.
On the other hand, there are precision instruments that will be treated with care and which will not be dropped or have their probes stuck into dangerous places. With these meters you are going to pay for accuracy and precision.
My inclination would be to get at least one of either kind according to your needs. Two meters in any case are better than one.
Offline PedroDaGr8
Also, the Brymen 829 might fit the bill as well. CatIV 1000V protection, 0.08% DCV accuracy, temp measurement, capacitance measurement to 25mF (25000uF), hfe is rubbish in any meter (much better building your own curve tester)
You mention measuring 0.005ohms. You are NOT going to find that in hand held that I know of. That type of measurement iirc is going to require a kelvin clip measurement.
Also, LCR measurements are a complex thing. Specifically the L part (and the advanced C parts). There are basically toys (the $50 LCR meters) which are just one step above useless and the real stuff (typically $200 and up).
Offline Lightages
  • Canadian po
Yes the Greenlee 860 is the same, but costs more just to have their name on it. You can get the Brymen BM869 from www.tme.eu.
Well now you are talking about another type of meter. A clamp meter is another whole can of worms. If you want just an industrial meter for work, AND need a clamp meter then just have a look at the Flukes and pick one you like. I don't think any of them have a low impedance measurement mode.
For your own use, well it gets pretty wide open. What do you want to spend? How accurate do you want it?
My short list of meters right now:
Safe meters with good features and accuracy:
Brymen BM869
Brymen BM257
Brymen BM525
Amprobe 37XR-A
Amprobe AM-270
Amprobe AM-5x0
Amprobe AM-160 or 140
Full featured meters with low safety:
Uni-T UT71D
Lower end meters as good buys:
Uni-T UT61E
Digitek DT-2843R
Digitek DT-4000ZC
I really like he Amprobe 37xr-a, its not a lot of moneys, has capacitance up to 400 uF and inductance to 40H. This meter pretty much does everything I wanted except HFE and ESR. It is also rated 1000V, is there any reason not to use it at work?
Offline Lightages
  • Canadian po
I would not use the 37XR-A at a power plant as it is only rated CATIII/600V and CATII/1000V. It is not just the maximum voltage that counts. CATIII is not good enough for your work place IMHO. That meter would make a good all round home meter though even if it isn't the highest accuracy.
If you really must buy one multimeter that will do industrial power and will do electronics and don't want to spend more than $300, then the choices are the Brymen BM869 or Amprobe AM-160. The BM869 is the better choice. There is also the Extech MM570A which is an older rebranded Brymen. It costs more than the BM869 so that is why I didn't recommend it. BTW, avoid any Extech EX series.
If you want a home electronics meter then the Amprobe 37XR-A is a good choice. Then get a solenoid type meter for work if they make them with a CATIV rating.
And in case you haven't done so, read these threads:
https://www.eevblog.com/forum/testgear/a-list-of-multimeters-that-do-not-appear-to-meet-their-claimed-safety-specs/
https://www.eevblog.com/forum/projects/cat-ratings-and-interpretation/
https://www.eevblog.com/forum/testgear/brymen-bm869-short-review/
https://www.eevblog.com/forum/testgear/teardown-extech-ex570-my-first-but-also-last-extech/
https://www.eevblog.com/forum/testgear/extech-mm570a-arrived-as-replacement-for-ex570-but-is-it-better/
and of course watch Dave's reviews and other people's reviews on the other ones I mentioned.
Thank you, I will definitely read that stuff.
As far as the AMProbe for home use, you said it isn't the best accuracy, but it is a nice enough meter that it will meat the accuracy it claims, and not drift to far for quite a long time right? Ive heard the Amprobe 38 is pretty nice to and has datalogging I also planned to check in to it, if does EVERYTHING the 37 does, and doesn't have awful accuracy issues with data logging that will definitely be my home meter. Although i'm thinking a Hi accuracy BK with just the basics and then a separate LCR meter may be the better choice in the long run.
I never realized shopping for a decent meter would be so hard....
Offline Lightages
  • Canadian po
Yes, there are many choices and many problems with claimed safety and quality. The 37XR-A is a very good meter as is the 38. I cannot vouch for their accuracy but Dave has one and reviewed the 37 early in his videos. It will do for general component checking but if you want high accuracy for caps and inductors then yes you need a proper LCR meter. When the meter is to ONLY be used at home then you have many choices. Have a look at all the meters I listed before.
If you want to use it in power distribution work then stick with the Brymen BM869, Greenlee DM860A, some of the Flukes, Extech MM570A, Brymen BM859, Agilent U1242B, Amprobe AM-160A, and there are some others. This short list is in the $250 to $400 range.
