I had a brief opportunity to look at the MSO 4014 yesterday, at Emona's showroom in Sydney. I was interested in the digital part of the system, because I have never used a logic analyser inside a scope before (always had the PC versions). I was keen to find out how the scope integrated the two functions (DSO and LA) and how the interface handled the extra channels.
As you would expect, screen real estate is very precious when you suddenly go from 4 to 20 effective channels, and I am pleased to say the Rigol implementation was quite effective.
Initially I did *not* like the size of the digital waveforms, and the fact that they were only available in "Small, Medium, or Big" amplitudes (and as far as I know the sizes of each are fixed). Small is about 3mm vertical excursion, Medium is about 5mm, and Big is maybe 7 or 8mm. The interchannel spacing is also very tight, especially in Small. But with some experimenting around, I came to the conclusion that I could get quite used to it, and Rigol have a "Grouping" system where the user can group say 6 digital channels into one set so the size gets slightly bigger than if there were a bunch of 8 or 16 channels on screen all the time.
The scope does not make much distinction between an analog and a digital channel in terms of triggering. I did not have much time to play with this aspect, but it did seem that you could trigger from just about anything, from a simple edge to a word pattern and it is all time-synced quite nicely.
A video review of an earlier Rigol scope (the DS1000D if I recall correctly) mentioned that the 1000D had some issues with time sync between analog and digital channels, and quite a lot of jitter in the digital timebase (+/- 10 ns) ... I was able to check this in the MSO4014 and found the issue was not present. As far as I could tell, using a high bandwidth probe and the digital channels, there is less than 4 nsec differential between the scope analog rise and the digital rise (and my setup was not rigorous by any means).
The digital probe pod assembly was an OK system, the fly leads and syringe hooks were nothing to sing about but they looked serviceable. The Emona rep agreed that they had a lifespan, which I think is about par for the course. I am used to scope probes lasting for years, including the syringe fixture, so the idea that these little fellas will go to be with Jesus sooner rather than later is a bit sad.
The cost for the MSO 4014 with the serial decode for CAN / SPI / etc is $5318 inclusive of GST. This is at the upper end of the budget for me. I have ordered one unit and it should be here in Australia in about a month. I will write again when I have more to say about the device, after a few days of seeing what it can do and how easy it is to make it do stuff.
Thanks to those who have commented. The idea of having two scopes slaved together with a trig out is intriguing, and I don't know how that would all work in practice - would it be too much trouble ? or a lifesaver ? I think that I have had an occasion when I was doing digital work where I needed ten traces, and I only had eight at the time ... and at that time I would have gladly done such a workaround. But on a day to day basis, I would prefer one box that keeps the clutter to a minimum.
Regards,
Tony Barry
