Author Topic: advice for purchasing oscilloscope  (Read 1290 times)
Offline RiccTopic starter
« on: July 20, 2020, 06:31:24 pm »
hello everyone, I want to buy an inexpensive digital oscilloscope and I wanted to ask for advice.
I see:
Siglent SDS1202X-E
OWON XDS 3202E
Gw instek GDS1102-B
Rigol DS1202z-e
reading the various posts I'm thinking of the siglent, but I wanted advice from those who are experts and have tried them.
I will use it to test and repair car audio and home audio components.
Offline espenfjo
  • Country: no
Re: advice for purchasing oscilloscope
« Reply #1 on: July 20, 2020, 06:40:34 pm »
All of these will work for what you described.
Offline Fungus
« Reply #2 on: July 20, 2020, 07:04:34 pm »
All of those will show audio signals, no problem.
Do you own a decent multimeter and soldering iron? If not, factor that into your budget even if it means not buying the Siglent.
(and for car audio you might want something more portable...)
« Last Edit: July 20, 2020, 07:07:01 pm by Fungus »
« Reply #3 on: July 20, 2020, 07:24:12 pm »
I have keythley 2015, weller wr3000 Soldering station, i had owon sds7102v but now i sold it.
I need a good scope at budget price
« Reply #4 on: July 22, 2020, 11:19:36 pm »
I will buy a siglent,
Sds1102x or sds1202x-e?
« Reply #5 on: July 23, 2020, 12:28:36 am »
SDS1202X-E is better featured and has much faster processor than older SDS1102X.
The SDS1102X do offer a 8" display and 50 Ohm inputs if they are important however the 7" display SDS1202X-E is a better all round DSO.
Carefully check the datasheets here:
https://www.siglenteu.com/digital-oscilloscopes/
Offline pidcon
  • Country: my
« Reply #6 on: July 23, 2020, 10:42:25 am »
Hi Ricc. I can only speak about my own GW-Instek GDS-1054B, which is just a lower end model of the oscilloscope you considering. I'm very happy with it, since it does the job very well and having four channels is useful. I needed its large memory record depth 10 Mpts. The scope apparently can be installed with apps from GW-Instek. Size is rather larger than other lower end scopes.
You should also consider the Keysight InfiniiVision 1000 series, particularly the DSOX1102A or the newer DSOX1202A.
« Last Edit: July 23, 2020, 10:46:59 am by pidcon »
Offline tv84
  • Country: pt
« Reply #7 on: July 23, 2020, 10:56:14 am »
This thread would have helped you a lot. But it fell apart... Maybe you still can read something interesting besides the typical scope advices.
Offline uargo
« Reply #8 on: July 23, 2020, 01:30:59 pm »
of these oscilloscopes that you put I would choose the siglent.
If you can spend a little more, around € 500 you have the 4 channel Siglent SDS1104x-e:
https://www.batronix.com/shop/oscilloscopes/Siglent-SDS1104X-E.html
Or around 600 € you have the Micsig 4-channel portable and with battery:
https://www.batronix.com/shop/oscilloscopes/Micsig-TO1104.html
https://www.batronix.com/shop/oscilloscopes/Micsig-STO1104C.html
« Last Edit: July 23, 2020, 01:36:46 pm by uargo »
