Author Topic: Adventures in Retrocomputing: hacking a 7.5 digit HP 3456A  (Read 13908 times)
Offline borghese
  • Country: si
Re: Adventures in Retrocomputing: hacking a 7.5 digit HP 3456A
« Reply #25 on: October 01, 2018, 11:58:21 am »
Hi Simon
Is there a possibility to also have the Gerber files of the CS with LTZ1000?
Cheers
Borghese
Offline Silicium81
    • Technical forum
« Reply #26 on: January 03, 2022, 03:55:33 pm »
I testing the firmware for 7.5 digit on my 3456A, it's work fine, thank's . To choose the firmware, I used the lsb of the GPIB address to select A16 from the daughter board. Thus, for even addresses, the original firmware is accessed, otherwise it is the 7.5-digit firmware.
I still have a few boards ... (21) If you want one, it's free for the board and 3 € for shipping cost international.
https://youtu.be/_LAhAGpToPY
More informations: https://vae-tech.forumactif.org/t259-remise-en-fonctionnement-d-un-multimetre-65-digits-hp3456a#2295
The file for programming an 27C010 (128kb memory) and memory adress plan is added in attachements
« Last Edit: March 17, 2024, 03:53:24 pm by Silicium81 »
Electronic engineer with a passion for mechanics
The following users thanked this post: lowimpedance, borghese
Offline bsdphk
« Reply #27 on: January 03, 2022, 06:20:21 pm »
the '58A is also measuring internally to 9.5 digits and these could be seen.
Oh, my. That sounds like a project begging to happen. :popcorn:
You do not need to do anything special, just configure your HP3458A with OFORMAT DREAL and you will get everything it's got.
As for disassembling the HP3458 firmware:  I've done it, but I'm not sharing because it is a live product.   Stay away from the HP-IB parser and you'll be fine.
Offline coromonadalix
« Reply #28 on: January 03, 2022, 06:42:40 pm »
Pimp the processor section with an raspi and a touch screen  loll
Good work guys,  impressive
For the 3458,  once the 9th digit is set,  does it stay set upon power off and power on again ?  does it flick like crazy ??
