Author Topic: Advantest R6243 teardown and repare  (Read 15783 times)
Offline ketil bTopic starter
« on: November 27, 2015, 11:16:11 pm »
Hi all
I scored this SMU for a steel. It would pass its self tests then throw a over heat error. After a bit of probing about I reverse engineered the temp sensing circuit and found that R91 was a dead short. After a little bit of soldering I have a working SMU.
I know has already been a teardown of this unit , so i won't repeat that and hopefully add to it.
This thing is deep 460mm from the front panel to the back and heavy 15kg, a third of the inside is the power transformers.
The board on top of the heatsink look like the high voltage board this might be the only difference between the R6243 (110v @ 2A) and the R6244(20v @ 10@)
Now to sume pics
thanks
ketil
Re: Advantest R6243 teardown and repare
« Reply #1 on: November 27, 2015, 11:21:04 pm »
And sume more pics of the digital / analog control.
thanks
ketil
« Reply #2 on: November 27, 2015, 11:22:41 pm »
And sume more
thanks
ketil
Offline deadlylover
« Reply #3 on: November 28, 2015, 02:46:36 am »
Very nice thanks for sharing.
Here I have its older sister, it's not every day you find a power supply (okay it's a SMU, a bit more posh =P) with Alpha bulk foils and a LM399 inside. I've seen the same unit use Alpha hermetic sealed resistors, looks like I picked the short straw though, oh well.  ^-^
« Reply #4 on: November 29, 2015, 12:27:06 am »
I've seen these pop-up from time to time and thought it would be interesting to get one and compare it to the one I have. Your wand it's a lot more modular than the one I have and my one doesn't have an lm399
Thanks
Ketil
Offline deadlylover
« Reply #5 on: November 29, 2015, 03:53:44 am »
One important point for the older TR6143, I don't think you can change the input AC supply voltage if buying one from overseas, I didn't see anything obvious anyway.
Offline Jay_Diddy_B
« Reply #6 on: November 29, 2015, 04:57:22 am »
Look at the fuse holder / power input at the back. There may be a voltage setting there.
Regards,
Jay_Diddy_B
Offline deadlylover
« Reply #7 on: November 29, 2015, 05:26:34 am »
I couldn't find anything unfortunately, the unit has two transformers (I think) and they looked to be sealed up pretty well, the covers were folded in and not screwed on. I suspect the taps are hiding inside them but I gave up tearing the things down after 20 minutes.
Offline TrexREXX
  • Country: ru
« Reply #8 on: November 29, 2015, 11:55:33 am »
thanks
ketil
Hello
My Advantest R6243  the test results in an error  +344 VSVM 110 V +FS
Voltage at the control points TP1,TP1, TP3, TP4, TP5, TP6, TP7 TP8 are too high
You can measure the voltage at the control points TP1,TP1, TP3, TP4, TP5, TP6, TP7 TP8?
Thank you
« Last Edit: November 30, 2015, 02:36:24 am by TrexREXX »
« Reply #9 on: December 01, 2015, 09:18:48 pm »
Hi i can do those measurements but have to clear some projects off my bench first
Thanks
Ketil
Offline TrexREXX
  • Country: ru
« Reply #10 on: December 02, 2015, 07:39:58 am »
Thanks
Ketil
OK!!
Thank you
Offline TrexREXX
  • Country: ru
« Reply #11 on: December 18, 2015, 05:12:14 am »
Thanks
Ketil
Hi ketil b
I repaired the Advantest R6243  :) :) :)
Some resistors on the payment located over
radiator were in break.
Now everything works
But there were questions on tension on control points
You couldn't help me? |O
I made the plate
               TP9 GNDC
TP1 +139V =+165V     TP5 -139V =-165V
TP2 +91V  =+111V     TP6 -91V  =-111V
TP3 +55V  =+73V      TP7 -55V  =-73V
TP4 +31V  =+42V      TP8 -31V  =-42V
Offline DEHiCKA
  • Country: aq
« Reply #12 on: March 19, 2016, 12:13:26 pm »
Just revived couple of those beasts!
3 cracked resistors and one TI's OPA627 opamp. The opamp was tough to figure out, it has inconsistent resistance disconnect inside it's case  :o
Not to mention OPA627 costs freaking $25 per piece. Funny fact, chinese even sell fake OPA627's wich have AD744 silicon under the hood: Original vs. Fake
Thanks, AD nowadays makes it's $5 analog - ADA4627
BTW, anyone has some luck with Cal menu?
I don't have "Cal Switch Set" on mine units. GPIB command XENT also missing, but X? is present, so maybe Cal entering is hidden on earlier firmwares?
Any thoughts?
« Last Edit: March 19, 2016, 04:07:33 pm by DEHiCKA »
The following users thanked this post: vinovino
Offline gamalot
  • Correct my English
    • Youtube
« Reply #13 on: May 20, 2016, 12:55:41 pm »
Any thoughts?
You don't have the "Cal Switch Set" menu entry because of your R6243 is working in the R6143 compatibility mode.
You can release this compatibility mode by pressing the MODE and DIRECT buttons then power on.
I'm a poet, I didn't even know it. |  https://youtube.com/@gamalot | https://github.com/gamalot
Offline TrexREXX
  • Country: ru
« Reply #14 on: May 23, 2016, 10:47:43 am »
Any thoughts?
Thank you!
Online aronake
  • Country: hk
« Reply #15 on: October 08, 2023, 06:30:45 am »
Any thoughts?
What error message did it show when faulty? which 3 resistors replaced?
Online aronake
  • Country: hk
« Reply #16 on: October 09, 2023, 04:30:31 am »
Any thoughts?
Long time ago, but do you remember, have a picture or can make a picture of which resistors and which OPA627 was changed?
