I THINK THIS MAY EXPLAIN A FEW THINGS,
These are the official Release notes, Keeping in mind that
1. I said i never saw this before
2. My scope before the 11 updates was on version 2.1
[Supported Model] All the MSO/DS2000A Series Digital Oscilloscopes
[Latest Revision Date] 2019/01/29
[Updated Contents]
v00.03.06.00.00 2019/01/29
- Fixed the bug of wave displaying after AUTO
[History]
v00.03.05.04.00 2018/04/02
- Inproved the wave updating
v00.03.05.03.03 2017/06/26
- Add new models of DS2102E and DS2202E
- Fixed the error of some Traditional Chinese menu
- Fixed the bug of EDU version
- Fixed the bug of wave stop updating
v00.03.05.00.01 2016/07/20
- Modified the naming rule for saving screen snap
- Fixed the bug of the wave stop updating
- Fixed the bug of Math expression
v00.03.04.02.01 2015/12/14
- Fixed the sensitivity in EXT trigger mode
v00.03.04.01.00 2015/10/10
- Supporting the EDU models for education market
- Standard with 28/56M memory depth and advance triggers options in EDU
models
- Opening the interface for replacing the Logo by AE in EDU models
- Fixed the scope freeze when changing the timebase in high-resolution mode
v00.03.03.02.06 2015/06/17
- Added the persistence of XY wave
- Added the French language menu
- Supporting the license file installed by U DISK
- Supporting the installation of bandle option
- Optimized the SCPI command system
- Supporting the remote access to decoded data
- Fixed the bugs of waveform reading
- Fixed image storage - Improve the stability the LAN interface communication
v00.03.03.01.00 2014/12/25
- Only Setups data can be saved without UDISK inserted
- Update the library of PictBridge
- Update the library of LXI
- Modified some SCPI commands
- Fixed the bugs of picture data saving in the SINGLE trigger mode
v00.03.02.00.00 2014/09/03
- Fixed the invalid measurement when the trigger status is Wait
v00.03.01.00.04 2014/08/22
- The Ultra Station can't download the wave table data
- Fixed the crash issue of using "AUTO" function in decode mode
v00.03.01.00.03 2014/04/15
- Added phase and delay measure of different edge
- Added the setting of power status
- Upgrade LXI driver
- Optimized the storage menu operationand i think this is the answer. this only came in in Version 3.1v00.02.01.00.03 2013/11/04
- Added the AUTO disable command
- Added multi-language (German/Korean/Poland/Janpa etc.)
TAKE NOTE PEOPLE WE NOW HAVE SUPPORT FOR... JANPA, HELLO TO ALL MY JANPANESE FRIENDS OUT THERE
I don't know about you but i was wondering when they would bring in support for Janpa - Fixed offset error when the amplitude of source is over 1.6v
- Fixed the bugs in trigger when it is Pass/Fail mode
- Fixed the bugs in waveform reading
- Optimized the AUTO trigger mode in every horizontal scale
- Fixed bugs in FFT operation
v00.01.01.00.02 2013/06/06
- Added file name when printing screen
- Optimized source setting for DS2000-S series
- Fixed trigger delay in 500uV/div
- Fixed trial license lost when do self-calibration
v00.01.00.00.03 2013/04/01
- Added SCPI command for decoding data
- Optimized the sampling rate in AC or Ext trigger
- Optimized the speed of PNG file storage
- Increased the sampling rate in ROLL mode
- Support DS2000-S series
- Fixed the cursor window error when change cursor mode
Switched the position of channel in XY mode (GOOD TO SEE THEY GOT ONTO THIS AND FIXED IT, I REMEMBER DAVE DOING A VIDEO ON IT)==============================================================================
So it would appear that rigol threw me a curve ball and made me think that these files were all created automatically at one point
and then became corrupted.
Suprising that they themselves didn't know that this was just the storage memory structure and the slots were placeholders
WOW
