Throwing a spanner on top of the preverbial battery. I have a use case for testing not only things like solar panels, charge controllers etc, but also multi cell batteries.
The multi-cell battery problem is, I grant a bit unfair. Nobody is going to hook a 6 series battery up to 7 individual voltmeters. Thankfully there is specialist hardware ... also with varying price, accuracy and quality. I have said hardware, but it's old, crap, under-rated (3 digit) and needs up graded. Until this morning my most advanced BMS was a "Turnigy" LiPo field charge monitor (allows you to charge/discharge multi cell packs from a basic charger while it monitors and balances the cells). The "cheap" ones are usually 3 digit. The really cheap ones the accuracy is a coin toss. The slightly less cheap ones will all over-read consistently, nanny state. It's the tricky part of finding the ones which have open firmware, schematics and reviews highlighting it can be calibrated properly... at at least 4 ideally 5 digit cell voltages, at least 8 of them, but I'll not turn down 16 channels.
On the bench testing a "nano" scale low power solar project with a single LiPo cell, I ended up with some really janky measuring apparatus to be able to read all the various currents and voltages. Things like:
Using a PSU as a voltmeter by setting it to 0 A current limit.
Using a DC Load as a voltmeter by setting it to 0 Ohms.
Using an INA3321 3 channel shunt monitor module an MCU and a TFT. (not very low power though!)
It's at those times having a little row of cheap 4 digit meters would be handy.
This morning I got 2 JK-BMS boards. I haven't tested them yet, but they are meant to be the mutts nuts for the purpose of monitoring (and maintaining) multicell packs.
