Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
Advantest r3132 test port levels and poor sensitivity.
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Advantest r3132 test port levels and poor sensitivity. (Read 3044 times)
jry
Newbie
on:
November 23, 2014, 07:40:06 pm »
I have a R3132 with poor sensitivity ..at least -30dbm low.
Fails the calibration and RF selftest ...cal signal too low.
Found a document on the advantest group that goes through the second LO alignment.
In there it shows the 2nd LO output at the sampling port at roughly -8dbm ( picture of SA output of the port shows -18dbm but had a 10db attentuator in line )
Looked at mine and see roughly -20dbm on a power meter showing a -12dbm difference which may be due to the 2nd LO buffer MMIC being defective.
WOuld liek to see if anyone has verified the levels on a functional r3132 .
Looks like there a two 1st LO sampler SMA ports ( one may actually be used for the TG option ) and one for the 2nd LO mentioned above.
There are other unused SMB ports which may be of value in troubleshooting if there was some information on their function.
Would be great to get a maintenance or service manual for this unit but it appears they never made it out of the factory.
Thanks for the help in advance.
Logged
jc81382
Regular Contributor
Country:
Re: Advantest r3132 test port levels and poor sensitivity.
Reply #1 on:
February 02, 2016, 11:05:47 pm »
Any chance you were able to figure anything out?
I am also having an issue running the Self Cal and get a 807 Error. I also Fail the RF Self Test.
Thanks
Logged
fozzyvis
Regular Contributor
Country:
Reply #2 on:
July 16, 2017, 04:46:17 pm »
@jc81382: same question to you...
Did you fix yours?
Dieter
Logged
tconil
Newbie
Country:
Reply #3 on:
June 17, 2020, 06:23:35 am »
Hi
Same problem, same question !
Did you fix this issue ?
Thanks
Thierry.
Logged
fozzyvis
Regular Contributor
Country:
Reply #4 on:
June 17, 2020, 09:50:45 am »
Hi Thierry,
Two moves, a home renovation and two children later... Haven't spent any more time with it I'm afraid. It is still standing glouriously unused on the shelf....
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
