Author Topic: HP 53310a opt 030 vs 031  (Read 984 times)
Offline wd5jfrTopic starter
« on: May 19, 2020, 04:37:50 pm »
For the hell of it I'm considering buying a HP 53301a so I can have some new fun or frustration  and also if I can  use it. I've got 2 Rb studs and a dead HP 5061A which probably has a bad Cs tube.. I see that both include the fourth BNC on the bottom right corner and go to 2.5 GHz.  But other than 031 provide for digital RF communications, I can't understand what digital RF communications means and use.
Thanks
Hank WD5JFR
Offline Tomorokoshi
Re: HP 53310a opt 030 vs 031
« Reply #1 on: May 19, 2020, 05:25:14 pm »
Option 30, Channel C, is included in Option 31. Here is the User's Guide for Option 31:
http://userequip.com/files/specs/826/HP%2053310A%20Opt.%2031%20User.pdf
It appears the main features from the manual are:
- Software to support some automatic measurements
- Internal downconverter for higher resolution measurements
- Increased sampling rate. Note: This appears to be 8 MHz. (This was 1992, after all.)
Here is the overall datasheet:
https://literature.cdn.keysight.com/litweb/pdf/5966-4092E.pdf
« Reply #2 on: May 19, 2020, 07:08:20 pm »
Thanks for the 2 links that I was unable to find.  Now I can forget about opt 030.
Offline SoundTech-LG
« Reply #3 on: May 30, 2020, 09:13:40 pm »
Questionable PS schematic...
