Author Topic: Help needed with Fluke 8845A SCPI commands  (Read 1684 times)
Offline ledtesterTopic starter
« on: October 16, 2020, 04:31:09 pm »
I'm trying to control a Fluke 8845A via the serial port, and I'm having trouble making sense of the documentation in this manual:
https://xdevs.com/doc/Fluke/8846A/8845a_8846a_programmersmanual.pdf
Some simple commands I've tried work like (see page 36):
*IDN?
DISP ON
DISP OFF
SYST:VERS?
but others don't, like:
SYST:TIME?
DISP ON:TEXT "Hello"
Are these not supported on the 8845A?
And then on page 38, the MEAS? command only works if I put the meter in Fluke45 mode.
And these examples of page 39 don't work in either the 8845 or Fluke45 mode:
MEAS:volt:ac? 10
MEAS:diod? ON
On page 31 FUNC "VOLT:AC" works, but FUNC "CAP" doesn't. (of course - the 8845A can't measure capacitance.)
I think I'm missing something basic here.
« Last Edit: October 16, 2020, 08:45:13 pm by ledtester »
Re: Help needed with Fluke 8845A SCPI commands
« Reply #1 on: October 16, 2020, 08:59:21 pm »
Ok - I think I've figured it out. What I was missing was putting the meter in remote control mode with SYST:REM.
Offline alm
« Reply #2 on: October 18, 2020, 04:16:05 pm »
Thanks for posting that update. I guess is
is because it also supports GPIB. With GPIB the GPIB controller will assert Remote ENable whenever you send a command. Apparently for RS-232 this is an explicit operation you need to do.
