I understand some civilian industries are very procedure driven. Makes sense really. Medical and nuclear power generation to name a few.
The B-17 Flying Fortress is very complicated to get in the air and back down again, because there is a sequence of events that need to happen just right, or your flight ends prematurely in a bad way.
Not until the check list was invented and mandated did the accident frequency drop enough that they could go to war and get shot down by external causes. Source:
USAF When you have people that might be under a lot of pressure performing complicated procedures, you want the procedures to be unambigous, as fail-safe as possible, and free from traps.
Imagine being the radio operator in the movie Crimson Tide, trying to fix a VLF receiver with the two highest-in-command officers on the boat standing over him. The EE with their fantasy and skills
might make a Doc Brown appearance and conjure up a better-performing receiver from a chewing gum, a steel comb, and some cling film from the galley since their Brymen can measure the MF thanks to its frequency response, but the petty officer will
reasonably reliably swap a component or sub-assembly, adjust the PSU regulation to perhaps 2% precision using a Simpson 260, slap the receiver together, and receive the message.
Likewise, the only non-manufacturing organisation I've ever worked in that took ESD seriously was the military. Probably because they have so much gear, run it so long, and have a lot of paperwork to get a FRU issued that there actually is some follow-up on causes of failure. Consequently, there is procedure.
