Author Topic: So which scope to buy  (Read 9124 times)
Offline mrpacketheadTopic starter
  • D Size Cell
Re: So which scope to buy
« Reply #25 on: March 22, 2017, 07:11:34 am »
I've short listed the RS2004 and the Keysight 3000.     I can have 2 2004's for the price of one 3000, but the 3000 is upgradable ( and potentially hackable ) to 1GHz...
Offline BravoV
  • +++ ATH1
« Reply #26 on: March 22, 2017, 07:22:41 am »
The ethernet eye diagrams are probalby the thing that pushes the spec requirement out.
I'm a noob, pardon for this question, say you got your scope that fits in your need and its fully capable to display the eye diagrams of ethernet signal as you wanted.
What kind of potential problems (just name the common ones), once you have a perfect eye diagram displayed at your scope ? And the potential fix for it ?
  • D Size Cell
« Reply #27 on: March 22, 2017, 07:58:33 am »
Simplistics, you can use it to determine the 'quality' of a repeatitive serial data stream.
Online tggzzz
« Reply #28 on: March 22, 2017, 09:11:26 am »
https://www.google.co.uk/search?q=eye+diagram+techniques
The wackypedia article isn't very helpful, but the next two are. In general look at manufacturer's application notes.
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #29 on: March 22, 2017, 11:17:49 am »
MSOX3000(T) vs. RTB2004 is not clear cut - there are significant plus and minus points on both sides so you'll need to look at both in detail based on your requirements.
Day Job: Mostly LEDs
The following users thanked this post: mrpackethead
  • D Size Cell
« Reply #30 on: March 22, 2017, 06:56:27 pm »
In deed its not. It might even be a case of buying both...   The RTB2004 would be a significant upgrade to the Rigol that is on the cal/repair desk.    the extra capabilitys would be handy.  Its almost a decvision that doe'snt need to much mor ethinking.
Offline alm
« Reply #31 on: March 23, 2017, 12:28:10 pm »
Depending on where you live and the R&S/Keysight presence there, you may be able to get a loaner so you can try them side by side for your specific applications.
