Thank HighVoltage,
I still considering which one probe is better for me.
While Fluke i30S bigger in size, it have flat mv:A ratio in all diapason (0-30A) that is 1:10, when SL261 have same ratio only for 0-10A and 1:100 for 10-80A
Same time i30S have 50 Ohm output and easy to use with scopes and DMMs, when SL261 have 1MOhm and probably work good only with high impedance DMMs.
Also for frequency response, i30S more preferable. Top diagram for i30S, bottom - for SL261
Any case you can send me offer in PM.
I have a CP-05A and it works as it should. I bought it from China through Ebay.
Probably it work well, but have you any datasheet for CP-05A?
