Author Topic: UT181A - Inquire Recording and time duration - how work ?  (Read 1623 times)
Offline pavia.luigiTopic starter
« on: August 29, 2017, 10:27:28 am »
Good Morning guys.
Someone can please try to explain how work the specific datalogger function named as "Inquire Recording"
available inside the Uni-T UT181A multimeter ?  Inside the user manual is not clear specified.
I will try to understand if this function is comparable as the "EventRecord"of a HiEnd datalogger Fluke multimeters.
and Also, during the video reviews available on youtube, regarding the datalog function at specific interval,
i see that with a sample interval set with value of one second, the last indicator "Sample Duration" seems do not change,
and the value indicated exceed the 9 days...
How can be possible? the instrument have only 20000 sample possible.
Please answer my question because we would buy one of this.
Thanks a Lot.
Luigi
Offline ufi
  • Country: ru
Re: UT181A - Inquire Recording and time duration - how work ?
« Reply #1 on: August 31, 2017, 03:14:13 pm »
No long time to check, but I think:
20000 - records for manual saved values
10000 - records in continous mode with >800000 samples shared for all records.
Best regards
