What do you recommend for a decent accuracy low(ish) current probe? I want something that has good accuracy in mA range and up to 5A (though I probably won't probe anything over 2A, so 2A or 3A is fine, whatever).
Also, hopefully not insanely expensive. Ideally, I'd like something under $500. Used is fine. If somebody has something awesome they want to trade for my 3532-50, PM me. 😉
Most common use would be tube guitar amp stuff, which mostly ranges in the low mA, but heater current might be significantly higher in the 1.5A level. Also my FUtracer tube curve tracer, but that's mostly the same levels. So 5A is overkill.
I understand there are other ways to measure this, that's not the point. I want to see things on the scope screen for fun, not due to any necessity.
Thanks,
Josh
