Most meters will do similar, especially in an electrically noisy environment such as a lab and is the result of the leads picking up some microvolts from the airborne magnetic fields radiating from other equipment or even mains cables near by. Its no big deal in the grand scheme of things, I mean 0.0001 is not going to make your readings invalid.
My 6.5 digit meter will happily read 0.00003v with no leads being plugged in unless I null the reading, which I don't because it is such a small insignificant number. Even if I do null the reading, it will still flicker between 0.00000 and 0.00001
