Author Topic: M4070 LCR Meter  (Read 12893 times)
Offline rstor22Topic starter
M4070 LCR Meter
« on: April 06, 2013, 03:45:34 pm »
Hello Everyone,
I am looking to purchase an L/C meter and originally was thinking of the LC200A (my budget is under $100USD):
http://mpl.jp/lc/LC200A%20%20EN%20V5.0.pdf
Recently I came accross the M4070 LCR meter:
http://kwansnet.dyndns.org:1080/shares/public/User%20Manual/M4070/M4070%20ManualV1_1.pdf
Which seems to be better than the LC200A (see chart at link below):
http://www.ebay.com/itm/M4070-AutoRanging-LCR-Meter-Up-to-100H-100mF-20MR-1-accuracy-5-digit-display-/321036981265?pt=LH_DefaultDomain_0&hash=item4abf4b9411
I want to get everyone's opnion on the M4070 LCR meter and if it is worth it for the price (approx $60 USD).
Thanks!
Offline Hydrawerk
Re: M4070 LCR Meter
« Reply #1 on: April 06, 2013, 04:40:27 pm »
I would never buy it. It is a strange LCR meter. It has too few functions. It is even impossible to manually set the test frequency (1kHz.....100kHz). Never buy unknown products from unknown manufacturers. I recommend the CEM DT-9935 or similar LCR meter, they are all based on the almost same chipset. See this for pros and cons: https://www.eevblog.com/forum/testgear/cheap-lcr-meter-cem-dt-9935/
« Last Edit: April 06, 2013, 04:42:21 pm by Hydrawerk »
Re: M4070 LCR Meter
« Reply #2 on: April 08, 2013, 07:01:59 pm »
Thanks for the feedback Hydrawerk. At the moment I really only needed a capacitance meter so I ended up purchasing a BK Precision 820 for $15, similar to the following:
http://crownassets.pwgsc.gc.ca/lotImages/FS173573.JPEG
I'll hold off on the LCR meter until I am ready to purchase a proper one.
Offline Hydrawerk
Re: M4070 LCR Meter
« Reply #3 on: April 10, 2013, 02:58:18 pm »
Why not, most LCR meters will not work up to 1000mF capacity.
Offline pmaggi
  • Country: uy
Re: M4070 LCR Meter
« Reply #4 on: May 13, 2013, 02:20:25 pm »
I've recently bought this lcr meter. I've played around a bit with it and it seems to work ok. All the components that I have measured with it are within the specified error.
Although is a bit bigger than I expected and it looks a bit "chinese", it works.
For only $49.99, you canĀ“t go wrong  ;)
Offline ekwan1970
Re: M4070 LCR Meter
« Reply #5 on: May 23, 2013, 10:19:38 am »
Offline N TYPE
Re: M4070 LCR Meter
« Reply #6 on: May 23, 2013, 12:59:26 pm »
Jestine Yong is a boss when it comes to SMPS repair
