Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
Advantest R6552 Specs
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Advantest R6552 Specs (Read 776 times)
chick0n
Regular Contributor
Country:
on:
June 15, 2022, 02:53:55 pm »
Hallo, dumb question:
The Datasheet says the Sensitivity is: 0.1uV, 100uOhm, 10nA DC.
The lowest Ranges are: 30mV, 30Ohm, 3000uA.
So can it Really measure down to 0.1uV, or just 30mV?
Logged
Kleinstein
Super Contributor
Country:
Re: Advantest R6552 Specs
Reply #1 on:
June 15, 2022, 04:11:11 pm »
The lowest voltage range is 30 mV. 0.1 µV is the resolution in that range. Obviously there is no 100 nV range - very few meters have such a small range.
Logged
chick0n
Regular Contributor
Country:
Reply #2 on:
June 15, 2022, 04:39:09 pm »
so it cant measure less than 30mV?
Logged
J-R
Super Contributor
Country:
Reply #3 on:
June 15, 2022, 05:30:10 pm »
It's a 319,999 count DMM, so in the 30mV DC range it would be able to display as low as 00.0001mV (.1uV) and up to 31.9999mV. This excludes any accuracy discussions.
Logged
Kleinstein
Super Contributor
Country:
Reply #4 on:
June 15, 2022, 08:04:59 pm »
Quote from: chick0n on June 15, 2022, 04:39:09 pm
The lowest range is a bit over +-30 mV. One can of cause also measure smaller voltages. The 30 mV range is so to measure up to 30 mV and less than 30 mV is the normal case. 100 nV resolution is already quite good and sufficient for thermal EMF and similar small voltges in the 10s of µV range. Much better would need special connectors as the normal banana plugs may lead to errors of a few µV if not careful.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
