The load is build around two SOT-227 power devices mounted on opposite sides of the heatsink tunnel.
Front panel is driven with an LPC2368 controller. There is a second LPC on the I/O board in the back of the device. This seems to connect with the main CPU via an opto-isolated serial interface.
I was somewhat surprised to find an ordinary linear power supply with multiple mains transformers in this device. There is no clue about the design date of this machine (PCB datecodes are 2014), but as far as I know, it hasn't been that long ago that this model replaced their previous load LD300...
