I scored a pair of these little cuties recently.
Dainty wee things, 115mm high (41/2") (Case & feet removed) by 225mm wide (83/4") by 360mm deep.
Massive
3 inch 95mm display.
Specs 15 MHz Max input 300V DC+AC peak or 600V p-p
Long looked for manual with schematics:
http://www.download-service-manuals.com/download.php?file=Aaron-8331.pdf&SID=p7q2q1u430i6ltslu975m7r9d441 pages 2.8 Mb
See following post for manuals specific to NZ models that were mostly ex NZ Navy:
https://www.eevblog.com/forum/testgear/aaron-bs-310s-cro-mini-teardowm/msg3828221/#msg3828221So in keeping withe the EEVblog motto, I didn't turn it on, I tore it apart.
The controls are set out just like a traditional CRO and include nearly all except AC trigger coupling and graticule illumination.
No Dual or Delayed timebase.
They both came with nice little vinyl overcoats with a few dozen perferations on each side to match the case holes, but not so many in number.
Obviously cooling is not a problem with these units.
Off with the jacket and a few screws later the case and carry handle just slide off the rear. Easy.
Imagine my suprise when I spot this yellow 12V NiCad battery pack.
10 "sub-C" cells, there's a spec for the battery on the base of the unit: 2A...guess thats 2 A/hr
Multi volage 120 or 240 VAC internal switch.
Circuitry layout is simple and neat, inputs down the LH side terminating at the vertical amps...all on one PCB. Nice.
Timebase, sweep and Horizontal amp on the RH PCB. Also nice.
There is a botton PCB, full width and ~ 2/3 the length of the scope. It is the only SS PCB.
It is mainly PSU, battery charging, main PSU (single 30V linear) and the CRT HV supply housed under the Ali cover below the CRT.
All componentry is facing inwards and with the outer cover removed all PCB traces are easily accessable for measurements.
Componentry is all through hole, IC's 4000, 74LS and the like. There are no hybrids that I could see, the bulk of the work done with BJT's with the exception of a 2SK228T (6 lead Dual Fet?) and a HA1127 DIP14 (5 Transistor array) IC in each of the channel inputs.
All preset trimmers are semi sealed types.
So time to turn it on....
You little beauty.
Bit of a fiddle and all seems to work as it should.....except the battery.
So time to hunt out why, nackered or just not charging.
AND the other thing missing ....a MANUAL......anybody? Found.
So what will I do with these little beauties..... just might give them to newbies plus the cost of probes
.... but not until I find a manual first.
