Edit: As mentioned in later posts, I had assumed that most DSOs could be set to Edge trigger on
either (i.e. every) Rising and Falling edge (as Rigol, Agilent, R&S, Instek DSOs do). This appears to be incorrect - and that many (all?) of the lower-cost ones will only trigger on
alternate Rising and Falling edges.
If you're not sure if your DSO supports
every Edge, you can test very quickly by setting it to 5ms/div, then sending it a
sine wave (DS1000 series won't work with square waves) between 1 - 12Hz (step 1Hz). If none of those frequencies produces a stable, non-moving waveform on a single edge, then your DSO is skipping potential triggers - and this technique won't work.
