Yes, you don't really hear much, there are no announcements even with improvements or new firmware. Even the marketing is very timid.
That said there is no external development of apps to date, not even an SDK. There is a programmer's guide but that's for controlling the DSO via network connection; I have not tested the network connection. Yes, a programmer could add apps including a serial decode and more, which would then compete with its more expensive models but how good it would be compared to more expensive models is anyone's guess.
But lets see what is available now to anyone if they chose this DSO.
No function generator, however the compensation port has a frequency adjust from 1k to 100k as a fixed amplitude and duty cycle square wave. They also added a external sync on the same port, undocumented.
GDB-03 is a stand alone board that generates test signals for a how-to-use a DSO course. The app simplifies using the DSO so a newbie needn't know how to use a DSO to see the demo waveforms.
The DVM app is a just a large display of the AV and DC voltages. You can get the same thing in the measurement function.
The Digital filter is a very useful function missing in 1054B as shipped. IMHO, it a mandatory app and I use it a lot. It comes as a basic function in many DSO that compete with the 1054B. It does low, high and recently added, bandpass filters. The cutoffs are very sharp [its a very high order filter], so its extremely useful and comparable to among the best DSO available. For example, the same filters on the Rigol 1052e are barely usable as the rolloff is too wide, very low order filters.
The Datalog app is a programmable screen capture. You can set the duration of each capture [ seconds to hours of data per capture] as well as the total run time.
I've used all the functionality except the GDS03 module, network connections, and the go-no go app shipped with the DSO. To date, there are no bugs I can find that impact measurement quality. For example, in the Datalog app using 'file function' screen caps cannot be viewed, but can be in the Utility app on the DSO. Its a user interface 'bug' but causes no issues except UI, otherwise logged data is correct and at the right intervals.
While it appears the 1000B offers far less than competitors were is shines is the quality of the measurements. Its hard to define since its qualitative, but in general there is no unexpected interaction between functions, measurements are stable as expected, and what is stated in the spec sheet is what is does at minimum, or better. This is what you'd expect only from top players in the DSO market as the video shows.
For example, FFT functions are a simple index of raw computing capability and eevblog has a video comparing this DSO line against others.
It shows what the 1000B can do and what the UI is not, jump to 9:00 for the 1000B review specifically.
Saturation,
Have you come across additional information about the apps available for this series? I did a rudimentary search with nothing obvious as to where the app dev is taking place (in house/open) nor what sort of capability is available to app developers. I'm mainly interested as a consumer... programming is not my forte.
A serial decode app would be fantastic but I don't even know if that's feasible?
Just for fun - I see this list of apps available on the download tab of the gw instek site. Has some sort of function generator recently been added?
APP Software 1 en 581 2016/02/15
GDB-03 Function Module for GDS-1000B Series. (It supports GDS-1000B V1.00 firmware or later.)
APP Software 1 en 327.7 KB 2015/09/18
The DVM apps. of GDS-1000B Series.
APP Software 1 en 341.4 KB 2015/09/18
The digital filter Apps of GDS-1000B Series.
APP Software 1 en 337.9 KB 2015/09/18
The datalog App for GDS-1000B Series.
