Thsinde 210E, seems an improved version. DC: 0-200uA with 0.1uA resolution
AC DC Current Digital Clamp Meter - 100A 6000-Counts Low Impedance Voltage 1 mA Reading Auto Range Multimeter Tester with Temperature,True RMS (Red)
1mA Sensitivity: 1mA sensitivity when measures AC/DC current by clamp.
Multi Functions: This true rms 6000 counts auto-ranging clamp meter can measure temperature, capacitance, low impedance voltage, frequency, resistance, continuity, AC/DC voltage, AC/DC current and live wire check
AC DC Current Clamp Meter
Low impedance LOZ: Max 600V Resolution 0.1V
Resistance: 600Ω/6kΩ/60kΩ/600kΩ/6MΩ 0.1Ω/0.001KΩ/0.01KΩ/0.1KΩ/0.001MΩ ±(1.0%+3counts)
60MΩ 0.01MΩ ±(1.2%+20counts)
Capacitance: 600µF/6000µF 0.1µF/1µF ±(4.0%+3counts)
Frequency: 60Hz/1000Hz 0.1Hz/1Hz ±(1.0%+5counts)
Frequency(by jaws): 60Hz/1000Hz 0.1Hz/1Hz ±(1.0%+5counts)
Buzzer: If the resistance is less than 30Ω, the continuity beeper sounds
Temperature: -20℃~500℃ 1℃/2℉ ±(2.0%+2counts)
DC current: 6A/60A/100A 0.001A/0.01A/0.1A ±(3.0%+5counts)
DC current(μA): 0-200μA 0.1μA ±(0.8%+5counts)
AC current: 6A/60A/100A 0.001A/0.01A/0.1A ±(2.5%+5counts)
DC voltage: 6V/60V/600V 0.001V/0.01V/0.1V ±(1.0%+3counts)
AC voltage: 6V/60V/600V 0.001V/0.01V/0.1V ±(1.0%+3counts)
https://www.amazon.com/dp/B08MX3PTBW/https://www.amazon.com/dp/B07P5QKQ5L/
