Hey Folks, im very new to this.. freshly made an account here, cause i dont know how to proceed...
I really hope someone could help me here..
I´ve made this Issue in Github to the UT210E
https://github.com/bdlow/UT210E/issues/2"bdlow" told me maybe to ask here for help.
I can´t read or write to my EEPROM anymore. Also, if i put the UT210E together again and power it on, it just says "ErrE". I modded it 2 times successfully. Before i tried the 3rd time, i recognized there was a soldered pin loose. So i soldered it tight again. The only thing that could be possible is, that the ground and the 3,3V pin had a short contact to each other. Does this instantly kill the EEPROM Chip?
I dont think it is the connection, cause it worked fine several minutes before.
Is there a way to reset or to rescue my EEPROM? Or do i really need to change the Chip?
Really big thanks for any advice given from you!!
