Author Topic: A look at the Uni-T UT210E  (Read 454031 times)
0 Members and 15 Guests are viewing this topic.
Offline Stinger
Re: A look at the Uni-T UT210E
« Reply #650 on: April 21, 2019, 09:13:56 pm »
Hello,
I received CH341A programmer and hacked UT210E DM1106EN multimeter. Big  thanks for your work !  :-+
I set :
  • 9999 counts
  • 100A to 1000A
  • Backlight timer disabled
  • APO 30min
  • DCV / ACV / DCmV / ACmV
  • Continuity / Diode / Resistance / Capacitance
  • 2A ACA / DCA / ACA dotless / DCA dotless
  • NCV / NCV mV / NCV dotless A
  • Alarms:
    DCV "beep" 750V / DCV "OL" 1000V / ACV "beep" 520V (because Vamp 750V) / DCV "OL" 750V (because Vamp 1000V)
    "A" warning disabled (because beep in Dotless 2A and NCV)
The following users thanked this post: Marco1971
Offline Stinger
« Reply #651 on: April 21, 2019, 09:17:33 pm »
It is possible disable beep sound when changing mode ?
Make μF default range for capacitance ?
Offline Martin72
  • Testfield Technician
« Reply #652 on: April 21, 2019, 09:21:10 pm »
100A to 1000A
Hmm...makes it any sense except you can set it to...
(Kierkegaard)
Offline stj
« Reply #653 on: April 21, 2019, 10:03:19 pm »
stop the beep? no.
set the range switch to start with capacitance before resistance/diode - yes.
Offline Stinger
« Reply #654 on: April 21, 2019, 11:37:16 pm »
100A to 1000A
El Coyote are making quick experiment to 400A.
https://www.eevblog.com/forum/testgear/a-look-at-the-uni-t-ut210e/msg1352044/#msg1352044
Offline Stinger
« Reply #655 on: April 21, 2019, 11:38:08 pm »
stop the beep? no.
I mean DMM display capacitance measurement only in μF.
Offline stj
« Reply #656 on: April 22, 2019, 09:31:17 am »
no, you cant disable autoranging without pressing a button.
Offline pratap_369
  • Country: in
« Reply #657 on: June 12, 2019, 05:11:32 am »
My UT210E's current measurement are way off (around 300mA on 20A range and 150mA on 2A range) after I did the calibration (by pressing blue and yellow buttons while turning on the meter) .I did realize that I shouldn't have done that after reading the whole thread  :(. Is the calibration is the main reason that gives the inaccurate reading.I did clean the contacts of the selector wheel but  the readings are same.
could somebody help me out whats wrong?
here is my eeprom data
Offline Svici
« Reply #658 on: June 14, 2019, 01:06:02 pm »
Just bought an UT210E from UNI-T Official Store on AliExpress, and it come with a missing row of 19 capacitors on PCB.
 It works fine as far I can tell, just I am not sure how good is this “new version” of it. See the pictures.
Does anybody have an idea of the role of the capacitors, and the values of them.
« Last Edit: June 14, 2019, 01:10:03 pm by Svici »
Offline Hydron
« Reply #659 on: June 14, 2019, 01:15:26 pm »
I think the row of missing caps is normal (from memory of the innards of mine), but I could be wrong.
You at least have the newer chip which supports a higher number of counts (after EEPROM mods are applied).
Offline Mortymore
  • Country: pt
« Reply #660 on: June 14, 2019, 02:35:31 pm »
All I can add is that I have one with caps, and my father-in-law has one without them, and his clamp is more accurate than mine. But that may be only casual.
Offline Svici
« Reply #661 on: June 14, 2019, 02:46:51 pm »
Actually I was thinking to add the capacitors myself, but I’m not sure what values are needed, so maybe I just leave with it as it is.
Waiting now  for the eeprom programmer to arrive from China...  :)
The following users thanked this post: mauroh
Offline pratap_369
  • Country: in
« Reply #662 on: July 05, 2019, 03:25:16 am »
anybody
Offline MosherIV
« Reply #663 on: July 05, 2019, 07:06:49 am »
Have you tried the zero button?
Have you demagnetised it?
When testing, are there any other magnets near by?
Are there any large ferrous object near by?
The following users thanked this post: Marco1971, pratap_369
Offline pratap_369
  • Country: in
« Reply #664 on: July 11, 2019, 08:28:32 am »
I tried everything,I even built a degaussing coil for the demagnetization.Even after the degaussing the readings are still the same |O
Offline MosherIV
« Reply #665 on: July 11, 2019, 07:01:25 pm »
Sounds like the calibration has been disturbed.
You will have to recalibrate the meter.
You will need to set up known values of current, possibly Volts and Ohms
Offline pratap_369
  • Country: in
« Reply #666 on: July 13, 2019, 04:53:01 am »
 [/quote]
[/quote]
the voltage, resistance and every other readings are spot on except the current readings.
Do you know how to re calibrate the meter?
I could setup known current values but I don't know how to calibrate
Offline MarkL
« Reply #667 on: July 21, 2019, 04:06:28 am »
I just picked up a UT-210E from Amazon.  A great little meter for the price.
Can someone explain what "V.F.C." mode does?  A half hour of searching and playing with the meter itself has not turned up anything definitive.  Thanks.
Offline bitseeker
« Reply #668 on: July 21, 2019, 08:04:07 am »
VFC mode engages a low-pass filter for use when measuring variable frequency drives. Hold the Select button for 2 seconds to enable it.
The following users thanked this post: MarkL, Marco1971
Offline Terry01
  • Country: scotland
« Reply #669 on: July 21, 2019, 12:18:09 pm »
Cool!
I've had mine for a while and never knew about that. You learn something new every day  :)
Sparks and Smoke means i'm nearly there!
Offline 001
  • Country: aq
« Reply #670 on: July 30, 2019, 03:02:49 pm »
So long tread  :-+ UT210E was invented 6 years ago
What about new alternatives in 2019? (I.e. same performance and Low DCA range)
Few "noname" clamps based on the same chip but has 6000 counts in stock
Any opinions? I didn`t see "zero" or "range" button. Why?
« Last Edit: July 30, 2019, 03:46:32 pm by 001 »
Offline TurboTom
« Reply #671 on: July 30, 2019, 03:40:52 pm »
Except for the third one (which has a "Zero" button), the clamp meters shown are AC current only. Hence they don't need it.
The following users thanked this post: 001
Offline 001
  • Country: aq
« Reply #672 on: July 30, 2019, 03:45:15 pm »
Thanx a lot
and what about ACM91 instead UT210E?
The following users thanked this post: Trader
Offline pratap_369
  • Country: in
« Reply #673 on: August 09, 2019, 03:30:48 am »
anybody have any clue?
Offline 001
  • Country: aq
« Reply #674 on: August 10, 2019, 03:07:59 pm »
    I   hacked UT210E DM1106EN multimeter.
    I set :
    9999 counts
    Is it possible to get  9999mA range instead 2A?
    What is maximum crest facktor for DM1106EN in 9999 mode?[/list]
    « Last Edit: August 10, 2019, 03:12:50 pm by 001 »
