Okay guys, I managed to get my EEPROM dumped...
FF FF FF FF FF 0 80 E8 3 E8 3 FA 0 0 BE 3
70 17 98 8 BE 0 3D 3D 3C 3C FF FF A FF 40 FF
FB 99 A3 80 64 0 96 0 0 80 17 80 FB 7E 38 75
4E 2 9 39 1 9 D3 2 B 58 14 A DE 2 A 0
0 1 0 1 0 7 98 0 64 0 64 0 64 0 0 0
DE 78 B4 73 0 80 0 80 0 0 0 0 1 0 0 0
E3 7F 48 7E 1 0 FE 2A 0 0 0 0 0 0 0 0
97 80 0 80 49 85 E0 7C 18 6 0 0 0 0 0 0
0 0 0 0 0 0 0 17 0 0 0 19 1E 1B 4 7
0 0 0 0 0 0 0 16 0 0 0 18 0 1A 5 9
0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 A
0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 B
D 0 2 30 D 0 3 20 20 0 3 20 20 0 3 10
41 0 3 8 41 0 3 5 41 0 3 5 D 0 2 30
0 80 0 80 0 80 0 80 0 80 3D 2 D4 3 51 5
44 2 E4 3 6C 5 0 80 5A C7 EF F F 80 0 0
I'd like the usual mods (8000counts, longer backlight, DC v first, etc.) but not sure how & what to modify from the dump and how to write it back.
I'd double check that is a full dump , it maybe how AudioNoobs .ino prints? did you use his .ino Sketch? , as the dump should be 16x16 double digit characters....it almost looks like mine did when I had trouble with the Pin55 >wire>CAP not connected well or connected to GND instead.
Mine :
..Before EEPROM Dump...
FF FF FF FF FF 00 80 E8 03 E8 03 FA 00 00 BE 03
70 17 98 08 BE 00 3D 3D 3C 3C FF FF 0A FF 40 FF
3B 98 8A 81 64 00 96 00 00 80 17 80 FB 7E 38 75
4E 02 09 D6 01 09 94 00 0B 43 16 0A EC FF 09 00
00 01 00 01 00 07 98 00 64 00 64 00 64 00 00 00
A0 74 EB 6F 00 80 00 80 00 00 00 00 01 00 00 00
C2 7F 48 7E 01 00 A5 2A 00 00 00 00 00 00 00 00
FA 80 00 80 54 81 E0 7C 05 06 00 00 00 00 00 00
00 00 00 00 00 00 00 17 00 00 00 19 1E 1B 04 07
00 00 00 00 00 00 00 16 00 00 00 18 00 1A 05 09
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0B
0D 00 02 30 0D 00 03 20 20 00 03 20 20 00 03 10
41 00 03 08 41 00 03 05 41 00 03 05 0D 00 02 30
00 80 00 80 00 80 00 80 00 80 51 02 F1 03 6C 05
50 02 FC 03 8B 05 00 80 5A C7 EF 0F 0F 80 00 00
some other PICs attached too I saved from the Thread....
don't forget you need to copy YOUR location 50/51 to 56/57 to , should be mentioned in the .ino file.
Unfortunately I am no real expert on this , the count 6000/8000 depends on the Chip you have , mine is only good for 6000 for example.
KB.
