Time has passed since my contribution here...2017
![Roll Eyes ::)](https://www.eevblog.com/forum/Smileys/default/rolleyes.gif)
A quick follow up of a problem of one of my 2 UT210E (the one I have given to my brother).
I have to fix his FAAC D600 motherboard (from a motor garage door) which has failed and some burned part on it.
So, after having fixed it at home, I have gone to his home, and when I have rechecked the power voltage line, his UT210E reads 51V DC
![Shocked :o](https://www.eevblog.com/forum/Smileys/default/shocked.gif)
(for a 24AC 86VA transfomer, which I have checked at home at 24.85V RMS on my Keysight U1233A and with my Siglent DSO 68V peak-peak (34V max and -34V min)).
=>So big fail for this 6 years UT210e old that I have flashed and contributed for mod it here
https://www.eevblog.com/forum/testgear/a-look-at-the-uni-t-ut210e/msg1316832/#msg1316832 I have worked on it for about 3 hours, reflashing other 24C02 calibration file, checking many parts etc..
All other functions worked well.
Then I have removed fully the motherboard, and found the issue
==> Wear of the rotary switch !
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
2 traces have lost their solder mask as you will see on the photos.
I have put a piece af tape, and it is working again, with the good calibration I have made 6 years ago
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
Now I have to find how I can isolate this traces... will try some UV solder mask
