No, the rotary switch was on 2A position.
I took a look in the programmer, the supply for the eeprom seems to be controlled by the µC - which make sense because of 3.3/5V type switching.
And so it seems on the scope screen, it raises to 3.3V, for a short moment to 5V, then falling and this repetively.
Maybe the time the eeprom was supplied was too short, I don´t know.
I bought the 2010 because I want to read out an 93C86.
And this failed too, but in a"funnier way" :
You click reading and the message appear, reading complete but you see nothing except FF.
Disconnect it from the eeprom, it does the same...
Edit:
I´ll take the programmer at work on monday, then programming an 93CXX with our programmer to make sure it IS programmed and after this I try to read it out with mine.
If this fails, I know the programmer is defective...
