I promised these photos ages ago but only recently got some time to take them. Both are True RMS, CAT IV meters designed more for electricians than for electronics use.
The first meter is a very basic Greenlee DM-300 which I got on Amazon for $39. They also make some high end DMMs which price-wise are on par with the better Flukes, Agilents et cetera. It comes with a carrying case and some basic leads. The meter feels extremely solid with no twist movement at all. It's got a latched continuity beep, but long wire runs make it sound weak. Not enough lead in the pencil
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
![](http://petros.pl/eevblog/websize/image001.jpg)
The entire case is rubberized plastic which works well for field use. The anti-slip surface feels secure. The battery compartment is accessible by removing two machine screws (brass inserts).'
![](http://petros.pl/eevblog/websize/image002.jpg)
![](http://petros.pl/eevblog/websize/image003.jpg)
Once open, you get mooned
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
. The first thing that struck me was how deep the sides are (similar to the Flukes in Dave's reviews) which is obviously why the case feels so solid. I also noticed how nicely the foil had been designed and attached, and the large solder joints holding the terminals in. The buzzer is also one of the neater ones I've seen (from Dave's reviews, mostly...) There are also the same kind of arc slots and shields as the Flukes have. The PCB itself seems like a low end material, but I guess they have to save a buck somewhere...
![](http://petros.pl/eevblog/websize/image004.jpg)
![](http://petros.pl/eevblog/websize/image005.jpg)
The inside of the front of the case is simple and the LCD stays in place.
![](http://petros.pl/eevblog/websize/image006.jpg)
Judging from the difference in color, the contacts for the range switch and LCD are gold plated. The pushbutton contacts have the color and patina of plain copper. I'll leave real criticism to the experts, but to my layman's eyes, the quality of the solder joints looks good, as does the quality of the parts used. I was happy to see the solid design of the probe terminals.
![](http://petros.pl/eevblog/websize/image007.jpg)
![](http://petros.pl/eevblog/websize/image008.jpg)
![](http://petros.pl/eevblog/websize/image009.jpg)
![](http://petros.pl/eevblog/websize/image010.jpg)
![](http://petros.pl/eevblog/websize/image011.jpg)
![](http://petros.pl/eevblog/websize/image012.jpg)
![](http://petros.pl/eevblog/websize/image013.jpg)
The second meter is an Agilent U1211A clamp meter. It lists for $250 US. In use it seems on par with the Agilents that Dave has reviewed in terms of accuracy. It also comes with a calibration certificate from Agilent. It does everything I expected it to do except in its resistance range which only goes to 4K Ohms (ridiculous for a meter this price, but hey, Fluke does the same tight-ass kind of crap). It takes a while to settle on a voltage reading, but once there, it's good at updating. Many of the functions like backlight on time, continuity beep threshold, AC/DC default start mode etc. can be customized to your taste. It comes with a nice carrying case, a set of leads with interchangeable tips, and two sets of tips (4mm shrouded and standard exposed). I bought a set of Fluke alligator clips which fit perfectly. The cables are really nice on this meter compared to most of the ones that come with meters designed for electricians.
![](http://petros.pl/eevblog/websize/image014.jpg)
The case is good quality plastic but the clamp itself feels somewhat flimsy. The battery compartment is accessed by removing one machine screw, then prying the cover off. They need to polish this a little more since it feels like you're going to break something when you go to remove the cover.
![](http://petros.pl/eevblog/websize/image015.jpg)
The cover comes off with two plastic thread screws. Opening it up I found two PCBs layered together. I also discovered two LEDs which actually are exposed through the back of the case once the battery cover is off. I don't know what they're for - calibration maybe?
![](http://petros.pl/eevblog/websize/image016.jpg)
![](http://petros.pl/eevblog/websize/image017.jpg)
All the boards carry the Agilent markings, which is a good sign. This same case was used a few years back by Amprobe and I was a little concerned that Agilent had used the same stuff and just slapped their name on it. This photo shows two things that worry me a bit - the screw holding the PCB to the front of the case has stripped grooves and the solder joints look pretty bad. I don't know what's wrong with them, but they have a strange patina to them.
![](http://petros.pl/eevblog/websize/image018.jpg)
The two PCBs are attached with 4 machine screws. I noticed that Agilent has coated their surge protection parts with nice thick heat shrink tubing for added safety. There are also silicone gaskets at the base of each lead terminal that press against the front of the case. I like the way they made the electrical connections between upper and lower PCBs.
![](http://petros.pl/eevblog/websize/image019.jpg)
Here on the bottom right you can see a thick piece of high temp plastic that they use to protect this board from a blowout on the other board. It looks like they used gold plating on the rotary switch contacts.
![](http://petros.pl/eevblog/websize/image020.jpg)
I didn't try to take the LCD off - I probably would have messed it up
![](http://petros.pl/eevblog/websize/image021.jpg)
Front of the case is simple enough, just don't flip it or the rubber stuff falls out
![](http://petros.pl/eevblog/websize/image022.jpg)
This screw was missing (although it had obviously been there at some point... the release of the clamp meter line was delayed because of some part that had to be swapped at the last minute, so I guess someone forgot to put the screw back in!) and because of that, the PCBs flop around until you screw the back cover on again. Tsk tsk. The screw on the clamp seems to only hold the two halves together, so it didn't really seem like the clamp was attached to the meter body. Maybe that's why it feels flimsy.
![](http://petros.pl/eevblog/websize/image023.jpg)
Another shot of the stripped out screw head.
![](http://petros.pl/eevblog/websize/image024.jpg)
A different view of the ugly solder joints.
![](http://petros.pl/eevblog/websize/image025.jpg)
An in situ shot of the plastic shield doing its duty.
![](http://petros.pl/eevblog/websize/image026.jpg)
Overall, I'm a but disappointed with the quality of workmanship that I found inside this meter as well as with a few of the design decisions that went into it (battery compartment cover, clamp, 4KOhm limit etc.). It's a decent meter, but I can't really recommend it hands-down it to too many people at work. Sorry Agilent, you need to try harder!
