[/quote]
Then do you know any good 4,5 digit display LCD available on internet with a few extra segments for things such as db REL HV (even with different signs or names)?
There are lots of options for 3,5 digit LCDs but not as many for 4,5 digit ones. The new one will be shipped but if it turns bad I need to find a solution. Because the meter is in excellent condition. It is as accurate as my 87V for example and even more accurate for resistance measurement... I don't know if this is just a coincidence.
[/quote]
Rick
If you are indeed getting a Fluke replacement LCD , then I would not be in too much of a rush to think of another 'fix' straight away.
I have fixed a couple of 8050's with 'new replacment Fluke LCD's' some years ago and they are still working fine, (no hint of any failure!).
As to an cheapo generic LCD, well I have not found one yet, so LED's is probably your best alternative. Either way its more than just a few hours work!!.
So to recap, get your new OEM LCD and just wait and see over time. Besides you may just snag another more capable DMM as time goes on to add to
your line up.
