Indeed. And the DSOX2000 series from Keysight is one of the least interesting choices from the A brands. R&S RTB2004 is well worth considering.
The RTB2004 is nicer than the DSOX2000 but still not much competition for that Siglent SDS2000 HD. It can't even compare to the much lower spec'd SDS2000X Plus.
So, spec is better for Siglent SDS2000X HD than for RTB2004. But Rigol MSO5000 is even better, is it not? Yet I see that most people suggest Siglent over Rigol.
I want to buy a decent oscilloscope and did some research. Rigol seems to be cheaper spec wise almost every time. But then I started noticing other aspects, like responsivness, ease of use and UI in general. And Rigol is not so great in this area. And for me this is a very important area. Good user interface means less frustration, more joy to use and ultimately I would use it more often, spend more time and do more project. At least it is so with my other hobby - woodworking.
It is very tempting to get SDS2000X+ that has 20% discount till end of this year. On the other hand, UI of RTB2004 is so nice and I must admit beautiful internals (for example, trigger implementation is such that it can trigger even on not active channel because there is a separate path from front-end to triggers logic), but not yet hacked. Hack, I even considering to get a loan from bank and buy MXO44 that has even better UI and bigger screen...
While I don't need many other qualities of A-brand scopes (long production life, certificates and such), B-brands just don't cut it in this respect.
Am I crazy or is there others who think this way? Not that I'm big fan of Apple, but what is equivalent of iPad in oscilloscope world?
