My company just purchased a new HDG1022A function generator. It works fine in stand alone mode. Using the RS232 interface I can make the included .exe program work (with fidgeting). But I would like to write a BASIC language code and/or operate the unit with a dumb terminal application such as the windows Hyperterminal session. I can't follow the command syntax to make this work, I.e. In a terminal session, 88RS232 does not engage the function generator. But with the Hantek .exe program, if I type this command in the user interface window, I can make it work. But Hantek gives no no source code, just the .dll drivers. Do you have a source code, or better, a BASIC example I could look at.
With Regards,
Steve
