Author Topic: DC Bench supply, compact, portable and battery powered?  (Read 3454 times)
Offline sixtimessevenTopic starter
    • Flickr
« on: November 08, 2019, 11:01:45 pm »
Hi
I'm looking for a compact, portable DC "bench" supply to take with me for troubleshooting on site.
It should have 1-2 Outputs, ~1V to ~30V, 1-2A out, the usuall CC/CV etc functionality. Internal battery should primarily allow for quick testing and not add too much bulk. External USB / USB-C would be nice too so it could be powered via a laptop / power bank.
I have of course seen the chinese RD DP30V5A which can be moded with a battery and a boost converter into a small casing, but I was really wondering if there isn't a finished product out there yet?
Offline thm_w
  • Non-expert
Offline MiniWare
  • Country: hk
Re: DC Bench supply, compact, portable and battery powered?
« Reply #2 on: November 12, 2019, 09:27:52 am »
Maybe MDP-XP is now your only choice (productized)
https://www.youtube.com/playlist?list=PLDAP5iOpi-ALEPrbsNvlLjSR9RXcrce_H
ADDED BY MOD: Miniware manufacturers account.
Offline Magnum
« Reply #3 on: November 19, 2020, 08:13:16 pm »
Hello,
I am also looking for a portable battery powered power supply. 1-2 channels, up 2-3A max., up to 30V.
Is there anything else than the MDP-XP available meanwhile?
Offline Kean
    • Kean Electronics
« Reply #4 on: November 20, 2020, 12:44:02 pm »
Maybe the FNIRSI DC-6006L: https://www.aliexpress.com/item/1005001530484759.html
Only one channel, and no internal battery - but it can be powered off USB C PD.
When using PD you'll be limited by max voltage of about 18V as it is buck only no boost.  You can get more with a different external source.
I've got one on order, as it looks pretty neat.  There are reviews on Youtube (in Russian).
Annoyingly the link for the manual download isn't working.
Edit: Manual and software: http://www.fnirsi.cn/support
« Last Edit: November 20, 2020, 12:52:30 pm by Kean »
Offline Magnum
« Reply #5 on: November 22, 2020, 07:00:03 pm »
Hello,
thank you for the info.
I haven't found specs for ripple and noise, could you do a measurement when you receive yours?
