If the VIN number is 025 and the serial number prefix is US3919 or greater: Your scope has a hardware configuration that allows easy upgrading to the most recent
revision of software (version A.04.50 as of this writing). You can also easily perform a
system recovery on this scope.
System recovery
Order 3.5 Recovery VIN# 025 (Media: LS-120). Do not attempt to use the 4.30 Recovery
disks, as the older motherboard in these scopes requires the older disk image. Once you have
recovered to A.03.50, you can safely upgrade to the latest revision (A.04.50 as of this
writing).
Software upgrade
Order the most recent revision of the Upgrade disk available on LS-120 media, or download
this software from the locations listed below.
If you choose to download the software, you will need to transfer all the files in each .ZIP file
to a blank LS-120 disk. Then perform the upgrade in the usual manner (click Utilities |
Upgrade Software).
Note that the A.04.50 LS-120 upgrade is a “partial” upgrade that does not contain the
WebEnable software. To use the WebEnable feature, you must upgrade to A.04.30 before
using the A.04.50 upgrade.
A.04.30 Upgrade:
ftp://ftp.agilent.com/pub/callpub1/ddt/scope/548xx/Upg_Rec/4_3/4_3_upg.zip 3
A.04.50 Upgrade:
ftp://ftp.agilent.com/pub/callpub1/ddt/scope/548xx/Upg_Rec/4_5/4_5_upg.zip If the VIN number is 025 and the serial number prefix is less than US3919: When your scope shipped from the factory, it did not have the LS-120 (120 MB) floppy
drive. Officially, this drive is required to upgrade the scope to revision A.04.00 or higher.
The drive also makes it possible to perform a system recovery from LS-120 media. You can
easily identify the LS-120 drive by the gold icon in the center of the drive door. LS-120
drives also have an electronic (not mechanical) eject button.
If your scope has a standard floppy drive, you should consider upgrading to the LS-120 drive.
This drive will allow you to easily perform upgrades and system recoveries that are officially
supported. To upgrade your scope, you will need to purchase the E2633-68703 upgrade kit.
The kit includes the LS-120 drive, all necessary hardware for mounting and connecting the
drive, and an LS-120 0 disk containing the most recent revision of software.
System recovery
Officially, there are three methods of recovery available to customers: LS-120 recovery, hard
drive replacement, and service center repair. Alternatively, some customers have been
successful using third-party external CD-ROM drives.
The preferred method of recovery is via installation of the LS-120 upgrade kit listed above.
If your scope has this drive, order the 3.5 Recovery for VIN# 25 (Media: LS-120).
A second method is to replace the hard drive with a drive that has the operating system and
software preinstalled. Since hard drive part numbers tend to change with time, contact
Agilent Parts for the most recent part number. Consult your scope’s service manual for
detailed hard drive replacement instructions. Service manuals are available for download at
http://www.cos.agilent.com/manuals/scopes.html. A third method is to have the Agilent service center perform the recovery. Contact the
service center at 800-829-4444 to schedule this repair (choose the “repair and calibration”
option in the phone menu). A fee will be assessed for units that are no longer under warranty.
Some customers have been successful performing system recoveries with external CDROM drives from companies such as MicroSolutions. These drives connect to the scope’s parallel port. Since this method of recovery is unsupported by Agilent, customers are
responsible for all configuration of the external drive.
For the recovery to be possible, you will need to mount the external drive and boot the scope
from a floppy disk (the drive’s manufacturer may be able to provide this disk for you). At the
DOS prompt, you must be able to navigate to the drive and see the drive’s contents with the
dir command. If you can successfully get to this point, you should be able to perform a
recovery with a special A.03.50 recovery CD. You may download the CD image at the
location given below or contact Agilent technical support for a copy of this CD.
The following recovery software is available for download. This is an .ISO CD-ROM image
file. You will need to use CD burning software such as Nero or Easy CD Creator to create
the CD from this file. Do not simply copy the file onto the CD as this will not work.
A.03.50 Recovery CD:
ftp://ftp.agilent.com/pub/callpub1/ddt/scope/548xx/Upg_Rec/3_5/3_5_rec.isoSoftware upgrade
If your scope does not have the LS-120 drive, order the latest Upgrade disk that is available
on 3.5” Floppy media (revision A.03.72 as of this writing). Versions A.04.00 and higher are
not offered on standard 3.5” floppies.
Alternatively, you may download the A.03.72 upgrade at the following location. You will
need ten blank floppy disks labeled 1 through 10. When you execute the file it will create ten
folders; one for each disk. Copy the contents of each folder to the corresponding disk and
then perform the upgrade in the usual manner (click Utilities | Upgrade Software).
ftp://ftp.agilent.com/pub/callpub1/ddt/scope/548xx/Upg_Rec/3_72/ 3_72_upg.exe
If you have upgraded your scope to an LS-120 drive, you can upgrade the software to the
most recent revision (A.04.50 as of this writing). Order the appropriate Upgrade disk(s)
available on LS-120 media, or download this software from the locations listed below.
Upgrade Software).
A.04.30 Upgrade:
ftp://ftp.agilent.com/pub/callpub1/ddt/scope/548xx/Upg_Rec/4_3/4_3_upg.zipA.04.50 Upgrade:
ftp://ftp.agilent.com/pub/callpub1/ddt/scope/548xx/Upg_Rec/4_5/4_5_upg.zipIf your scope does not have an LS-120 drive but you do have a working external CDROM drive as mentioned in System recovery above, it is possible to upgrade to revision
A.04.00 or higher.
To upgrade your non-LS-120 scope to A.04.xx, you will need the A.04.xx upgrade software
on CD and the appropriate boot disk on a 3.5” floppy. You may contact Agilent technical
support for copies of these disks, or download the files at the locations given below. The
boot disk supports the MicroSolutions model 167550 Backpack CD-ROM drive. You may
need to modify the files for compatibility with your drive.
Boot disk for A.04.xx upgrade from CD (save contents to floppy):
ftp://ftp.agilent.com/pub/callpub1/ddt/scope/548xx/Upg_Rec/bootdisk/CD_boot.zipA.04.30 Upgrade files (burn contents to CD):
ftp://ftp.agilent.com/pub/callpub1/ddt/scope/548xx/Upg_Rec/4_3/4_3_upg.zipA.04.50 Upgrade files (burn contents to CD):
