Author Topic: Fluke 287 289 Firmware update version 1.16 now posted  (Read 21588 times)
Offline elex_enthusiast
  • Country: ph
  • Everything has user-salvageable parts inside!!!!
Re: Fluke 287 289 Firmware update version 1.16 now posted
« Reply #25 on: June 18, 2013, 03:12:54 am »
does the new firmware update requires calibration? :-DMM
Always learn how to break and fix things electronics!
Offline Uup
« Reply #26 on: June 18, 2013, 03:29:54 am »
I don't think calibration is required after an update, unless the firmware you are updating from would necessitate it (very early revision). I updated my 289 from 1.13 and didn't require a calibration.
Offline ben_r_
  • A Real Nowhere Man
« Reply #27 on: June 18, 2013, 03:50:28 am »
Yea shouldnt require an new calibration.
If at first you don't succeed, redefine success!
  • Country: ph
« Reply #28 on: June 21, 2013, 09:06:44 am »
i just updated my 287 and had no problem so far after updating the firmware from 1.12 version...the accuracy remains the same..thanks to fluke..
if ever you found something bad with your meter after updating please tell us..
Offline Chalky
« Reply #29 on: July 01, 2013, 10:40:42 am »
Real (cheapass) engineers don't like paying 50€ or 70 $ for FTDI chip and 2 IR diodes  ;)
Hey Nermash (or anyone), do you reckon, in theory that a similar homemade cable based on Silicon Labs CP210x would work on my 287?  Not having any luck, firmware app won't connect, and can't see anything with serial comms software (e.g. Hyperlink).  Cable works 100% fine on my Scopemeter 196.
Cheers.
Offline Nermash
« Reply #30 on: July 02, 2013, 06:34:10 am »
I am not sure, I have tried my IR cable with cheapo PL2303 clone, and it dind't work. Anyway, here is where I got the schematic and other things, it is chinese forum, but pictures are OK :)
http://bbs.38hot.net/thread-17883-1-1.html
One important thing it that with 287/289 IR TX must be inverted.
Offline dgm_mixtoon
  • Country: do
  • Hello!
« Reply #31 on: December 13, 2023, 05:07:18 pm »
hello, can you share the project, i have 287 fluke but the cable y expensive as a hell
the chinese web you posted before dont have access.
