Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
8482A vs N8482A
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: 8482A vs N8482A (Read 3948 times)
metebalci
Frequent Contributor
Country:
8482A vs N8482A
on:
February 18, 2024, 04:26:01 pm »
Is there a difference between these two other than the bandwidth (4.2 vs. 6 GHz) and the EEPROM in N8482A ?
Logged
R-1125F
Regular Contributor
Country:
Re: 8482A vs N8482A
Reply #1 on:
February 18, 2024, 09:08:01 pm »
The N8482A stores the cal factors in EEPROM so that they do not need to be loaded manually. The 8482 does not. The N8482A is compatible with the E4418B.
Logged
metebalci
Country:
Re: 8482A vs N8482A
Reply #2 on:
February 19, 2024, 07:31:15 am »
So other than the ease of use regarding the cal factors, no performance or other difference within the same type of use (certainly not more than 4 GHz and most probably up to 2GHz) and with E4418B ?
Logged
R-1125F
Regular Contributor
Country:
Re: 8482A vs N8482A
Reply #3 on:
February 19, 2024, 12:43:08 pm »
The dynamic range is different. It is a little better for the N8482A. The N8482A dynamic range is -35 dBm to +20 dBm and the 8482A is -30 dBm to +20 dBm.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
8482A vs N8482A
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
