Starting over all pots at center, as per the instructions. The previous owner did this. I have to go with it,4 chips and the main board were replaced.
Resistance measured on an HP 34401A
Picture's 1~4
1. This a 50.3 ohm terminated BNC TEE. With the 3ft cable the resistance is 50.65 through a banana adaptor
2. This a picture of a new BNC cable with a 50.1-ohm 2W pass through resistor on the trigger output (perfect)
3. This is the something but with the cable I was using for the main output.
4. This is the same cable as picture 3 but with the 50 ohm terminator resistor from picture 1
![WTF? :wtf:](https://www.eevblog.com/forum/Smileys/default/wtf2.gif)
This does not do this all the time. It could be doing this with the pass through I just can't get it to do it now
adjustment on page 9-4.5 to 9-4.15 came out perfectly.
What could make this do this? I have been messing with this for hour-----days before I stumbled onto this
I'm going to do the calibration to the end again, using just pass through on the main output and a 20 dBm on the trigger output. on the scope, for adjustments that use the trigger output on my counter HP 5334A has a 50 ohm / Z button do you see a problem with this idea?
