Hello everybody,
I've been watching Dave's show for some years now and finally followed his advice in getting an oscilloscope. Now, because of financial constraints, I got this 60£ (+22£ shipping) analog Tektronix, which is the little brother of the 2225 that Dave actually did a teardown on some time ago. Starting it up, there's a beam on the CRT, knobs work, the horizontal position is very jittery so that needs cleaning or replacing, other than that nothing obviously wrong.
Also got a cheap 60MHz (10:1) probe from a local supplier and tried it for the first time. I don't have a signal generator so first thing I did was try to use the probe adjust to see if anything will show on the screen.
After adjusting the compensation on the probe, the square wave looks great in my eyes, the time base looks a small amount off, but what I don't understand is why, when using DC coupling does the signal go to negative 500mV. Here is a clip to demonstrate what I'm talking about:
https://gfycat.com/LividBelatedDoe. Shouldn't it be above the 0 line?
Next thing I did was build a 555 PWM generator that GreatScott provided on his youtube channel (
This results in this showing up on the screen:
https://gfycat.com/DarlingMarriedIrishsetterhttps://gfycat.com/FrigidMelodicFelineNow I don't know if this is a product of the PWM generator or the scope itself, but there are two weird things I notice here:
1. that rising edge/begining of the upper line that keeps moving up and down
2. the horizontal jittering of the whole signal that is happening intermittently
Later on I tried generating a square wave signal using an android app and amplifier connected to the phone. That proved to be a relative success, exept after 800Hz the horizontal jitter shows up again. Any ideeas what these problems could be?
Edit: forgot to mention another troubling issue here - past 1KHz the visible signal on the scope appears to show as one fully visible graph and another dimmer graph superimposed but with a 180 degree offset. I'll get a picture attached later.
I also attached a normal transformer to the scope to look at a sine wave. This was the result:
https://gfycat.com/DarkSlipperyHairstreak. The shape looks a bit off. Tried it with a different transformer, same thing. When I tried it with the phone signal generator, it looked better, so again, I don't know what is causing that.
I now finally realize not having a function generator is a major hurdle in diagnosing issues and calibrating this oscilloscope.
Next thing I did was open it up. Internally it looks quite similar to the 2225.
It's clean and I saw no obvious signs of trouble. I've attached some pictures for you to see.
So, if you know how or what I could do to further diagnose this thing without a signal generator I would greatly apreciate any help. Some questions I am facing may simply be from my lack of knowledge so I'm sure there's something more to learn from this.
