I just went through a whole "project within a project (within an even bigger project)" of repairing a bunch of 16752A cards, tracking down cables and flying leads, and getting them working in my 16903A mainframe.
My 16903A had the Motorolla VP22 motherboard in it, and I thought I would just "put up with" the slowness of the unit, but after actually using it for a solid weekend, I got very frustrated with how slow it was.
I have since upgraded the motherboard to an Asus P5G43T-M motherboard with a core2duo E8500@3.16GHZ, 4GB ram, 500GB sata ssd running win7 64 bit sp1, and logic analyzer software 5.60. My power button to ready to go time is 50 seconds, and quite a lot of that is the bios before the OS boots, and the LA software initializing the 3 16752A cards. I think you could go to even newer motherboards, but you obviously need at least 1 old-school PCI slot (and for anything other than the 16903A, it has to be in the right location too)
But more importantly, the whole system is FAST - you can zoom and scroll traces without any lag, and it makes it MUCH MUCH more usable. It honestly feels like a modern and very useful piece of equipment that's enjoyable to use now. With the old motherboard, it was basically a chore to use, but if it's the only tool you have, it certainly gets the job done, it just took forever.
I also installed the logic analysis software into a windows 7 VM on my linux box, and I can do all of my offline analysis there without the actual logic analyzer running (and not having to listen to the fans drone away). It's very convenient to have the logic analyzer on one monitor, and ghidra (or whatever software you're working with) on the other monitor on the same machine, and no fan noise to boot!
What I gained:
- Much faster and responsive trace updates
- DVI / HDMI / VGA output on the motherboard (easier to connect to modern displays) - running it with a 1920x1080 24" LCD
- Can actually run a widescreen monitor at 1920x1080 (I couldn't for the life of me get the windows XP on the analyzer originally to give my any 16:9 resolution options with the onboard graphics on the motorola board)
- gig ethernet
- usb 2
- 64 bit os that can actually use 4GB of ram
What I lost:
- The internal monitor (well, it works, but it's one or the other, the internal monitor or the external, but not both or switchable with the buttons like it used to be) - the internal screen is pretty horrid, small, and low resolution (and only 256 color because of the awful graphics chip that drives it) anyway - no big loss to me
- The touchscreen (I just didn't install the driver, it is available, and I connected the serial cable from the PCI board to the motherboard) - don't use the internal screen so don't care
- The "Agilent screensaver" (ok, but does anyone actually care about this?)
Agilent is being stupid and won't give out any software other than the 2 versions they have posted on their website now. I was able to track down most of the versions from V4.40 to V5.90 (I have V4.40, 5.40, 5.60, 5.70, 5.80, 5.90).
The older version they have posted (3.67) is the last version that supports compiling the old Inverse Assemblers with visual studio into a .dll wrapper for use with the windows analysis software (as opposed to the older HP-UX software in the older 167x and 165x analyzers). The instructions to do so are in another thread (and I successfully did that for some IA's that I was interested in - I can verify they work)
I believe V4.00 is the first version that supports windows 7 (32 bit)
V4.40 and above all support windows 7 (64 bit)
V5.70 and newer are persnickety about some registry keys or else they complain that they're not being installed on a "valid frame" and refuse to work
V5.70 and newer are also a lot slower (reportedly by other people in threads here) and have more restrictive / more annoying licensing, and require more .Net dependencies, with no real benefit unless you have specific analysis hardware.
Yes, you can export .csv files, but if you're trying to look at differences of rather large traces (~300 - 400MB), I actually find their software works the best (using the "Compare" window). The only tricky part is to do that "offline" (either on the logic analyzer itself or on a separate computer / vm running the logic analysis software) with previously captured traces, you need to enable the "Data Import" license in the software. Otherwise you can only compare a previous capture to a live capture right now. All of the secret sauce to do that is scattered here in other threads.
With the original slow CPU and low RAM, it was an OK tool
With the upgraded CPU, more ram, and being able to run the same version of the software offline on another machine or VM, it's a much much more useful tool!
