I'm looking for a function generator and am noticing there's plenty to chose from, and not so many reviews/tests around. Basically I'm looking for something in the 25Mhz area, dual channel and can play arbitrary waves (1 Mpts minimum for the samples I want to play) and has a way to send the arb. wave over from my pc. (I can make my own software to make the waveforms, if the pc software uses an understandable format). A USB connection is good enough, I don't need LAN. Also I'm not a time nut, I don't care if the frequencies are not 0.0001% correct. I don't like jitter though!
I've been looking at used equipment, but most only have sine/square wave and are not arb.gens. Also it's hard to find anything in the EU.
So I'm looking at these devices for the moment :
Rigol DG1022 (20 MHz, 4kpts?)
Rigol DG1022U (25 MHz, 4kpts? is there any other difference?)
Siglent SDG1025 (16kpts)
Hantek HDG2002B (64mpts? there's a topic on hacking this one, I do want something that's reliable though!)
Then there's these which are a bit over budget :
Rigol DG1032z (8 Mpts, hard to find anything about this one)
Rigol DG4062 (this one looks really nice, but it only has 16kpts sample memory!).
Siglent SDG5082 (512kpts, I saw Dave's teardown and am not repelled by the flimsy build, the electronics look good enough to me).
I don't want to try my luck with Atten/Owon...
Looking at the memory of all devices, the only ones suitable seem to be the hantek, dg1032z and sdg5082 (barely)..
Am I overlooking some devices? Anyone have some recommendations? Which ones to avoid? Which one really stands out from the rest given the requirements?
