Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
EVB ESR Meter kit - full experience
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: EVB ESR Meter kit - full experience (Read 3421 times)
pixel63
Contributor
Country:
stat Roma pristina nomine, nomina nuda tenemus
on:
April 19, 2016, 12:17:48 pm »
I've just received my new ESR Meter Kit from EVB (Portugal), based on Bob Parker K7214 MKII original project.
I'll post my entire experience on the unboxing, assembling, testing, calibrating and using it on my repairs.
Bye.
Pixel63
Logged
..Pixel63
BurningTantalum
Frequent Contributor
Country:
Re: EVB ESR Meter kit - full experience
Reply #1 on:
April 20, 2016, 02:25:57 am »
I bought one of these kits many years ago. The design still looks to be the same today.
It works perfectly well for my purposes, and it has had a lot of use BUT:
The on/off switch is absolutely an appalling design. It doesn't work reliably or repeatably and drove me nuts. It consists of a TAC switch on the PCB with a length of silicone tube pushed over the tang. This has to be JUST the correct length to kiss the back of the membrane on the front panel. The practical movement of the membrane is less than the movement of the switch between 'not touching' and 'operated' so the switch has to be under some amount of 'pre-load'. Finally I removed the offensive item and mounted a small push button in the front panel, with a home-machined guard to stop accidental operation.
In addition the case is VERY tight for space and doesn't latch closed reliably because of this. In fact some brands of 'PP3' 9V battery are fractionally too wide to allow the case to click shut.
Regards, BT
Logged
pixel63
Contributor
Country:
Reply #2 on:
April 20, 2016, 10:06:52 pm »
ROUND 1
Unboxed, plenty of components, ohhh.
Here the images of the content of the kit and of the PCB from both sides.
I've soldered the resistors, the diodes and the sockets for ICs and displays (last image).
Logged
..Pixel63
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
